Http://windowsdevcenter.com/pub/a/windows/2005/03/22/word_macros.html
This would absolutely help you understanding on How to Run macros using batch file from Command prompt
Excel Workbook
.xlsx
The default Excel
file format. Cannot store VBA macro code or Microsoft Excel 4.0 macro sheets
(.xlm files in Excel 4.0).
Excel Macro-Enabled
Workbook
.xlsm
Uses the same basic
XML format as the Excel Workbook, but can store VBA macro code. Users saving
an Excel workbook that has VBA code or Excel 4.0 macro sheets (.xlm files in
Excel 4.0) are prompted to use this file format.
Excel Template
.xltx
The default file
format for an Excel template. Cannot store VBA macro code or Excel 4.0 macro
sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled
Template
.xltm
Can contain a
VBAProject part or Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Workbooks created from this template inherit the VBAProject part or Excel 4.0
macro sheets that exist in the template.
Excel Add-In
.xlam
A supplemental
program that runs additional code. Excel add-ins use the Open XML file format
to store data, and they support using VBA projects and Excel 4.0 macro
sheets.
Creating a batch file
MS-DOS users
Microsoft Windows and other users
MS-DOS users
To create a basic batch file in MS-DOS, follow the below steps that give you an example of how to create a basic batch file.
Batch file for what?
I once ran across a software called Dosbox that I used to run a customers dos based notes program in XP. It worked well, not sure about batch files, but worth a shot I suppose.
You can find info on it here - http://dosbox.sourceforge.net/
It might be helpful to explain what you would like the macro to do...
