Question about Baby Gear
Sharp atomic clock spc9000 won't read outside temp
3 Suggested Answers
SOURCE: resetting the atomic clock to the correct time zone, and outside temp to work.
For the Sharp SPC374T Atomic Clock - Time Zone setting- Press the 'Time' button once, the time zone will show where 'Day' usually is, use the Up or Down buttong to adjust.
For the outdoor Thermo, credit to my neighbor for this one. Remove battery from main unit, wait 2-3 minutes. Reload batteries. Once you get a reading from the outdoor sensor, hit the reset on the main unit. You will have to reset the time zone as described above, but this worked for me after 10 months of no outside temp showing up!
Good luck,
Doc
Posted on Jul 09, 2008
SOURCE: Sharp Atomic Clock Daylight Savings
I have misplaced the manual for my sharp Atomic clock, need to reset the time zone and shut off the alarm. How can I obtain a new manual?
Posted on Jul 10, 2008
My atomic clock does not read outside temp
Bring outside temp sensor indoors. Remove batteries from both remote and base. replace outside first with fresh batteries (Alkaline recommended). Then the base. Make sure they are on the same channel. When display restored, you can take the remote back outside.
Feb 28, 2018 | Home
Why does the outside temp read 135 f. when the local temp is 93 f.?
you have the sensor in the sun or close to something that absorbs heat,like brick or masonry,or window
Jul 04, 2015 | Sharp Atomic Wall Clock, Silver/Titanium...
How do I set my sharp atomic clock. Put in new batteries and set time and date on back of clock but the outside temp is not registering?
That makes scence, you have to have an outside temperature probe. If it is wireless it also needs batteries. Check manual for more details.
Nov 07, 2014 | Sharp Atomic Dual Alarm Clock Spc315...
The outside temp is not displaying
If the clock uses a remote temperature transmitter, you may need to replace batteries.
Jan 12, 2013 | Sharp Atomic Weather Station Alarm Clock...
How do i get the outside temp. to work
If you have a outside sensor add betteries.Wait for it to connect to the base. You may have to "reboot" ,remove batteries from base and outside temp sensor and replace both, Patiently WAIT I have a similar device and once a year I replace the batteries It takes a while for the devices to re-connect and set , the atomic clock as well. That said, How far is the Temp Sensor from the base unit? I set my outside sensor near the base to connect and move it on th outside porch (30' away) out of the direct sun and rain. I not sure if this is necessary but that the way I reset them.
Nov 04, 2012 | Sharp Spc315 Atomic Dual Alarm Clock
My oregon scientific indoor outdoor weather station with atomic clock just stopped picking up the outdoor readings, it won't switch to that channel any longer. tried removing and reinstalling the battery,...
I had the same problem, Since the outside temp wouldn't read, I figured it was the outside unit batteries. Went through half a dozen AAA batteries and wouldn't read. It was the indoor unit. Had the same bats I installed 3 years ago. DUH! Replaced the AAA, and all was well. When the inside batteries die out, it has just enough juice to read indoor temp, but not enought to sense exterior signal.
Oct 20, 2010 | Oregon Scientific Wireless IndoorOutdoor...
The outside temp sender won't work. We put new batteries in it, but it does not send a signal. It will not put an outside temp on the clock.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
Aug 18, 2009 | SkyScan 86709 Atomic Wall Clock
Outside temp on skycam atomic clock
Try changing the battereis in the CLOCK. When the batteries in the clock start getting low, the clock does not pick up the outside transmitter.
Nov 10, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Resetting the atomic clock to the correct time zone, and outside temp to work.
Good luck,
Doc
Dec 01, 2007 | Baby Gear
Baby Gear Logo
49 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
