Question about Oreck Vacuums
Vacuum overheating vacuum runs for a while, then turns itself off because overheated
  • 97 Answers
SOURCE: Overheating Hoover
Most likely caused by a lack of airflow. Check to see if you have airflow at the end of the hose. If not, Remove all of the hoses and ensure that they are not clogged. If there is airflow through the hose; check the air inlet immediately aft of the brushroll, inside the nozzle. This is a very common place for clogs to form.
Also note: contrary to some manufacturers claims, you can not clean (or wash, for that matter;) a hepa filter. The small particles are too embedded in the filter media to ever get completely removed, and the act of cleaning tends to damage the filters, even if you can't see the damage. This is why bagless life-spans, on average, are half the length of the life-spans of bagged vacuums.
Good luck,
-R
Posted on Aug 01, 2008
GoVacuum1
  • 6 Answers
SOURCE: Bosch Vacuum Cleaner: I changed
Greetings from GoVacuum.com,
It sounds like you may have a bad thermal switch inside the machine. Most vacuum cleaners have a switch connected to the motor, so if the vacuum cleaner is running hot, it will shut off to prevent any damage to your motor. You did all the right things by checking the bag, making sure the hose was NOT clogged, and replacing HEPA filter.
Most of the time on canister vacuums, the reason is caused by a clog in the hose, or somewhere in the powerhead. If you're sure that there is no clog anywhere, it is going to be the thermal switch on the motor.
Here's a link to the parts schematic for the Bosch upright vacuum. I hope it helps you in determining how to access the thermal switch. A word of warning to you before you try it, this is a very tough vacuum cleaner to work on, you may want to bring it in to a vacuum repair shop, as this is not an easy repair.
Here's the link;
http://www.essco.net/Customer/SchematicFrame.asp?FileName=Turbo%20jet%20upright.pdf
Please let me know if you have any other questions,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Posted on Aug 18, 2008
  • 294 Answers
SOURCE: Turns itself off
Your problem sounds electrical in nature. possibly the on/off switch. Take it to a reputable repair shop to determine the exact issue.
Posted on Oct 28, 2009
SOURCE: panasonic MC-V7395 Belt overheating/snapping
I have the same problem. I keep thinking I have fixed it, but then another belt breaks. I only have the issue when the roller is disengaged. (on bare floor setting). I did find that the unit was slipping back into engaged slowly, because the disengage mechanizim was not kathing prperly,. Tightened up a screw, and now appears to hold, but somehow the belt still get broken - I beleave it is an issue that the belt is not staying away from the drive when it is disengaged.
Posted on Mar 04, 2010
gokulegv
  • 144 Answers
SOURCE: My vacuum cleaner is not sucking. It's overheated and stopped
In this case it is motor problem, you can sort out only by calling the technician. Call the customer care and check out the cost for repair, if it is very high you can go for a new one and be in peace of mind.
Thank you.
Posted on May 08, 2010
Reset switch
There is no reset button it as a Thermal Cut Off
This vacuum cleaner has a special thermostat that protects the cleaner in case of motor overheating. If the cleaner suddenly
shuts off, turn the switch off and unplug the cleaner.
Check the cleaner for a possible source of overheating such as a blocked hose or clogged filters. If these conditions are found, fix
them and wait at least 30 minutes before attempting to use the cleaner. After the 30-minute period, plug the cleaner back in and
turn on the switch. If the cleaner still does not run, then call 1-800-282-2886 for customer assistance
this link below is the manual
http://dl.owneriq.net/b/b7517422-db37-404e-9da2-d898185942e5.pdf
Sep 05, 2013 | Eureka 4700A Maxima Bagless Upright Vacuum
Dysons animal overheats and turns off What do we
The electric motor inside your Dyson has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, next time it is switched on it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are available on eBay2_bing.gif for about £25, however replacing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Mar 25, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson wont turn on and its a bit smelly
It sounds like the motor has overheated and has now been irrepairable damaged.
The motor has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, the moment it is switched on, it just trips again.
Replacement motors are avaible on eBay2_bing.gif for about £25, however repalcing one requires good DIY skills and tools.
Mar 18, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Works intermittenly
Replacement motors are available on eBay for about £25, however replacing one requires good DIY skills and tools.
Feb 21, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Simplicity 7 Series Vacuum. Suddenly stopped.
There is a thermal reset button on your vaccum. It is on the rear of the unit, just below the attachments and next to the sticker with the serial numer etc on it. The vacuum is designed to turn itself of if too much heat gets built up to prevent it from "burning up."
Dec 13, 2009 | Simplicity 7850 Premier Bagged Canister...
Turns itself off
Oct 28, 2009 | Hoover Windtunnel Supreme U5280-900...
Just stopped running while vacuuming
When a vacuum cuts out while working, it usually indicates overheating. Most have a thermal cut-out, which will reset itself if given time to cool. The cause is usually a blockage of some sort.
Feb 15, 2009 | Kirby G6 Bagged Upright Vacuum
Shuts off/ peppershaker24@msn.com
it is overheating clean all suction ports well, as well as the brush. clean or replace all filters, especially the hepa. Hopefully the damage is not irreversible, if so the motor is most likely done for.
Oct 31, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
No suction
Sounds like your motor bearings are going bad. This is generally indicated by the motor overheating, and the heat transferring out through the motor pulley, which is where the belt attaches. So, your machine is overheating, melting the belt, and then tripping the thermal cutout. When it cools and you restart it, the belt is no longer functioning due to being melted, and this would make it not pick up on carpet. If you look at the motor pulley and it is turning blue: this is indicative of overheating.
The other possibility is that there is a clog, which is also causing your motor to overheat; so before you throw it away make sure all of your air pathways are clear.
The fact that you've had it 8 years is somewhat remarkable, however, since most vacuums of this type are averaging a 3-5 year lifespan. (And half that for bagless.)
So, check for clogs, and if it's not clogged, you're probably due for a new machine.
-R
Oct 01, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
88 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
