Question about Jura Impressa X9 Espresso Machine
Life span of the Jura Impressa X9 machine - Jura Impressa X9 Espresso Machine
My jura x9 says rinse fill
This happens when the machine is priming the thermoblocks(heaters) the machine is not registering water flow through the machine.blockage in water tank? pump not running? a thermoblock scaled up(blocked). first check the 2 flow meters in the machine located under the water tank. one of these may be defective or just stuck,
Aug 29, 2014 | Jura Impressa X9 Espresso Machine
Jura x9 water tank fill rinse
So what's the question?
https://www.capresso.com/customer-care-instruction-booklets.shtml
Check bean
Hi, I made a video how to fix your Jura step by step, good luck,,
http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
Aug 18, 2014 | Jura Impressa X9 Espresso Machine
Jura impressa x9 classic.
this problem is normally due to the flow meter not sensing water flow through the machine. possible causes are 1,lime scale in the thermoblock this may need replacing. 2, the pump has failed also may need replacing. 3. the flow meter itself is stuck , this can be dismantled and cleaned, if not then replacement is required. 4. a simple blockage from the water tank to the inlet . not a job for the novice..
Mar 30, 2014 | Jura Impressa X9 Espresso Machine
Jura Impressa X9 Espresso Machine Logo
74 people viewed this question
Top Jura Coffee Makers & Espresso Machines Experts
cramsey548
ray gallant
rich2481
Are you a Jura Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
