Question about Dymo LabelWriter Thermal Printer
Dymo label requires a dymo label printer be installed. make sure your label printer is installed and connected
    Habit-Forming:
    New Friend:
  • 177 Answers
You can purchase the printers for around $100/more or less and are fantastic to use. You can print lots of formats for different size labels. They don't need ink cartridges either, which is a huge plus!
Posted on Jan 22, 2018
  • 351 Answers
SOURCE: DYMO Labelwriter 400 printer software problem for Mac OSX
Dear Raymazz,
you can download a new version of driver for you dymo ,this driver is recently launch for MAC's . here is the link:
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=101
Cheerup and Be Happy always
Posted on Mar 18, 2008
SOURCE: Dymo Twin Turbo Labelwriter not printing stamps
This is the response from dymo stamp. I did as they said and am now printing stamps again.
We have seen this cause problems with the .NET framework Microsoft uses and Dymo Stamp uses. Follow these steps to correct it Step 1: Download Microsoft Windows Installer CleanUp Utility
1. Visit:
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
2. Save the file on the Desktop.
3. Please double click the msicuu2.exe file to install it on the computer.
Step 2: Remove .NET Framework
1. Click Start -> (All) Programs->Windows Installer Clean Up.
2. Please locate and remove Any .NET Framework 2.0 software.
After that, please perform the following suggestions to reinstall .NET
Framework 2.0 and its updates. Step 3: Reinstall .NET Framework Version 2.0 SP 1
Please download and install the following
Microsoft .NET Framework 2.0 Service Pack 1 (x86
http://download.microsoft.com/download/0/8/c/08c19fa4-4c4f-4ffb-9d6c-150906578c9e/NetFx20SP1_x86.exe
Note: When the "File Download" window appears, please click Save, and follow
the directions to save the file on the Desktop. After downloading all the
setup files, please double-click on each one to install them.
Posted on Apr 28, 2008
  • 7 Answers
SOURCE: dymo label 400 turbo.
It doesn't use ink so that's not the problem. more than likely it's one of 2 things. 1. you created a custom label layout and the text is just over the edge of it's printable area. Therefore, only hal of it prints. #2 Your using the wrong size label template on the software. make sure that the size you have loaded in your label printer matches the template shown size for size, inch for inch. The printer doesn't know (or care) what label you have showing on your software. It only knows what's loaded in your printer. So for example, if you have a shipping label on the software and put text to the bottom og it, it won;t print if you have an address label laoded in the printer.
Posted on Dec 31, 2008
SOURCE: dymo label point 200
Dymo website, Support Tab:
http://global.dymo.com/enUS/TechSupport/default.html
Drop down box and select your product.
Print out you instruction manual.
Posted on May 11, 2009
SOURCE: Dymo Labelwriter - Compatible Labels
printer says its out of paper after replacing it I still get the same message
Posted on Oct 05, 2009
I have a dymo 450 and it keeps printing 2 labels each time. Is there a setting off?
Make sure you use genuine DYMO labels, not compatible ones. Also, make sure you select the right size in DYMO Label.
You may have to disable bidirectional support: right-click the printer > Printer Properties > Ports > uncheck the option. ^CM
Sep 26, 2013 | Dymo ® LabelWriter® 450 Series PC...
Windows vista and dymo labelwriter 450
Here is how to upgrade the software:
1. disconnect the printer and make sure you log in as an administrator. If you need to, back up your contacts: Address Book > Export;
2. uninstall everything that says DYMO (Start > Control Panel > Uninstall) and re-start the computer (back up whatever should be saved);
3. install the latest Windows updates;
4. install DYMO Label 8.5.0: see the download link below(I suggest right-clicking the downloaded file and running it as administrator);
5. connect the printer directly to the computer only when prompted;
7. only use DYMO-made rolls - black stripes on the back, the logo and article number should be there.
tinyurl.com/dymolabel850pc
Also, please go to Start > Devices and printers > right-click the printer > Printer properties > Ports > clear Enable bidirectional support > OK.
^CM
Jan 07, 2013 | Dymo ® LabelWriter® 450 Series PC...
Printer will not print and prints more than asked
^CM
Aug 30, 2012 | Dymo ® LabelWriter® 450 Series PC...
At the end of a set of labels, my 400 jammed so I had to take off the front section to clear the jam. When I loaded new Dymo labels, it now doesn't print. Not sure if when I took off the front...
Welcome to FixYa.
Reset the printer by doing the following:While the printer is on, unplug the printer power cord.Restart the computer.Plug back the printer. Make sure all connections are properly connected.Unload an reload the Dymo labels.Then restart the computer again.Try to print.
Thank you for using FixYa.
Jan 04, 2012 | Dymo LabelWriter 400 Thermal Printer
Dymo 450 prints too many lables
^CM
Nov 23, 2011 | Dymo ® LabelWriter® 450 Series PC...
Dymo label writer 400 turbo will not print
Uninstall the software and disconnect the printer from your PC. Then reinstall version 8 of the Dymo Software (without the printer connected) and connect the printer when prompted by the software.
Make sure you are using version 8 of the dymo label software - it is compatible with Windows 7.
Apr 24, 2010 | Dymo LabelWriter 400 Turbo Thermal Printer
There doesn't seem to be any ink - labels come thru' blank, all connections are good
These Dymo LabelWriters are thermal printers which uses heat to print the labels, not ink. Be sure you are using labels compatible with your Dymo printer.
Dec 29, 2009 | Dymo LabelWriter 400 Thermal Printer
Printing error print system exception error
I had this problem with the LabelWriter 450 Turbo and it was a .Net Framework problem.
1. Uninstall the Dymo Label software
2. Click this link to download .Net Framework 4.0 http://www.microsoft.com/downloads/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
3. Reinstall latest version of your Dymo Label software (w/o printer connected to PC)
4. Reconnect label printer when prompted by installer
This should fix the problem
Dec 24, 2009 | Dymo LabelWriter Thermal Printer
This is the error message when openning the Dymo Software on Server 2008. We have openned this same softare successfully on other 2008 Severs. Exception EPrinter in module Labels.DLL at 0000643E6
http://global.dymo.com/enGB/Troubleshooting/LabelWriter_320.html
From this site.
    • The error message: "Exception Eprinter in module LABELS.DLL at ...." is displayed.
      or
      The error message: "Access violation at address ... in module DYMOLBL.EXE" is displayedA. This problem can occur when DLS 7.x was installed over DLS 6.x, without first uninstalling DLS 6.x.
      Solution:
      Delete the file Dymolbl.ENG.
      DLS will still work, however, all default settings will be incorrect.
      The settings will need to be set correctly.
      On the DLS menubar, click Preferences and set the preferences as desired.
      The default values are:
      Default label file folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Label Files"
      Default address book folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Address Books"
      Default clipart folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Clipart"
      B. An incorrect printer has been selected in the DYMO software.
      Solution:
      1. Start the DYMO Software.
      2. Click on File and point to Change printer.
      3. Click the LabelWriter model connected to the PC (e.g. Dymo Turbo)
      C. Occasionally, double-clicking the print command button in the list manager is not handled properly by the software.
      Solution:
      Single-click the print command button.
      D. An incorrect driver has been installed.
      Solution:
      Run the DYMO Driver Uninstaller
      Restart the PC and install the correct driver.
      To remove and reinstall the printer driver:
      1. On the Windows taskbar, click Start, point to Settings and click Printers (& Faxes).
      The printers window is displayed.
      2. Double-click the LabelWriter icon and delete any documents waiting to be printed.
      3. Close all programs.
      4. On the Windows taskbar, right-click on Start and click Explore.
      Windows Explorer is started.
      5. Double-click the file C:/Program Files/DYMO Label/Support Files/LW Remove.exe
      6. Unplug the LabelWriter's USB connection from the back of pc and click OK.
      7. Choose Select all and then remove.
      Once the driver has disappeared from the printers dialog box, click Close.
      Restart the PC.
      8. When Windows has restarted, on the Windows taskbar, click Start, point to Programs, point to DYMO Label and click Uninstall DYMO Label.
      9. Reconnect the LabelWriter to the computer and reinstall both driver and software.
Jun 16, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo LabelWriter Thermal Printer Logo
950 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
