Question about Hayward H Series Induced Draft Abg 100,000 Heater
Hayward h100ID does not do anything no fan no sign of life has power and gas
    Top Expert:
  • Hayward Master
  • 8,673 Answers
If calling for heat check safety circuit
Posted on Oct 01, 2017
SOURCE: Hayward Spa Heater H100ID blower will not stay on.
I had a similar problem and it turned out to be the solder connections on the control module. The connector that is soldered to this board (comes from the gas valve) needed to be re-soldered.
Posted on Jun 14, 2009
  • 139 Answers
SOURCE: Fan will not turn on. the heater is a hayward
most likely a faulty ignitor
Posted on Jun 21, 2009
  • 12 Answers
SOURCE: hayward h100ID ignitor not starting
There are many different things it could be with the fan comming on that means the heater is trying to fire. Make sure gas supply is on first of all. Depending on the gas line run you may have to try several times of turning on and off the heater to reprome the line. If no luck with that the next step is the igniter follow the small tube comming off the gas valve and folliw it to the burner tray try poking a small peice of wire through it from a wire brush it probally is plugged. Heater should fire after that.
Posted on Jun 26, 2009
  • 246 Answers
SOURCE: heater works fine for 5-10 minutes, then flame goes out
smeel gas? clean burners
Posted on Aug 25, 2009
  • 64 Answers
SOURCE: Hayward pool heater H100ID keeps blowing GFI
First, I don't see any heaters in my parts wired thru a GFCI. Why did you resolder inputs on board. Usually, those are not repairs that are acceptable. If the pins have shorted, then you need to replace the board. Could be a problem with the ignitor, but this might be one that you will need to call a pro in for. Did you install the heater yourself???
Posted on May 20, 2010
Fan won't start and won't ignite I have a Hayward h100id
check voltage going in if ok check pressure switch should have voltage on both leads if not check pressure switch or copper tube for clog
May 26, 2014 | Hayward H Series Induced Draft Abg 100,000...
Pool Heater. Hayward H100ID Starts fine and heats for about 5 minutes. Then heat stops. You can feel the blower its just cold air.
It sounds like your pool heater is not firing. I would check several things: the burner might be blocked and clogged, the gas valve might need to be replaced, the direct spark module might be malfunctioning, or the combustion blower might be cleaned. One of these is probably the issue. A service man can repair all of these problems.
Aug 08, 2010 | Hayward 100kbtu Pool Or Spa Propane Gas...
May 19, 2010 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Hayward h100ID ignitor not starting - I turn on the heater after the winter and hear the fan but no ignition
Jun 25, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward heater not working
You'll never get enough gas from a 20 pound tank. Even 100# tanks struggle to evaporate enough gas to keep up with that heater.
In the mean time, what is the output pressure on your regulator?
Jun 15, 2009 | Hayward H Series Induced Draft Abg 100,000...
May 30, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward H Series Induced Draft Abg 100,000 Heater Logo
192 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
