No sound from amplifier
I have no sound fro amp amp powers up normaly i have changed input source and there is nil change
  • 1 more comment
  • nuorigin Apr 14, 2008
    I also have no sound from our Europower EP1500 It was working, then only one side worked, and now no sound at all.
  • qluxor Sep 26, 2008
    had sound yesterday. today, have signal but no sound. SAMSON SX2400 AMPLIFIER
  • obeacon Jan 05, 2009
    System powers on, but no sound comes out. All lights on. Speakers, wire, source, fuse, do not seem to be the problem.
  • 682 Answers
1-check for blown fuse2-check for good cables to your loudspeakers
(no short circuit between cabels wire.)
about(nuorigin problem)-move the good speaker cables to the bad side and check if there is no sound the problem in your amplifier output stage and needs to be fix at workshop.
Posted on Apr 25, 2008
Russound CA6.4 amp / controller - 3 of the 6 zones can't switch source inputs.
I suspect the inputs will all go into an IC. You just need to trace one of them back till you come across it. Either the circuit around it will be the problem, or more likely the IC itself.
Jul 01, 2014 | Russound CA64IL Amplifier
Sound is only in mono how do i turn on sterio
you have to make sure you give correct stereo signal source to the stereo amp input, you can confirm this by changing your audio source to Left or Right. can your amp speaker out follow the sequence?
Feb 04, 2014 | Blaupunkt Car Audio & Video
NAD C320. Only one channel sounds. Problem with the volume control?
Did you try to switch the loudspeakers? Before changing anything always lover the volume and switch off the amplifier.
Assuming you tested already different inputs, you can be sure no cable from signal source is out or defect. (or did you nit check that first?).
When the amp is switched off, disconnect the speakers and switch left to right and right to the left output.. If the other speaker is quiet now, you are sure it is in the amp. Still his can be anything.
You can check the connections between the pre and main amplifier on the back side. When you have an extra set of interlink cables, perhaps you can cross the in and output there too. Take care every time you change something, lower the voltage and switch off the amplifier. Sudden clicks when switching on or changing anything can damage the amp and or the speakers.
Perhaps when you checked this you can locate where the problem is? Speaker, speaker cable, power amp, pre amp, (only a part of the pre amp.
Nov 12, 2013 | NAD C320 2-Channel Amplifier
Only two of my amplifier inputs are outputting sound correctly!
Odd one! Normaly you would loose a channel if the main amp was down, or the pre-amp was. But clearly the main is working. The only conclusion is that there must be more than one pre-amp and that's why the Tape section works. The only way to solve this one is to go inside and trace the imputs to where they join the PC board.
A helpful hint is that if you touch the audio section with a srewdriver, it will buzz! And since you have two channels which copy one another you can work out where the fault is. Because if it buzz's in the good channel, it should in the same place on the bad one.
WARNING don't stick your srewdriver on power parts, and don't short any part out with it.
Feb 09, 2010 | Teac A-H300 Amplifier
Whining sound in speakers that changes with RPM.
Check ALL the ground wires. Did you use a fuse block power source for the subs?
Jun 18, 2009 | 2000 Volkswagen GTI
Speakers are connected to pre-amp or power-amp? pls explain connections , what connects with what , between cd player + pre amp + power amp + speakers.
Do this, CD audio out jacks to the PRE-AMP INPUT jacks, then PRE-AMP OUT jacks to AMPLIFIER INPUTS then from AMPLIFIER to speakers, This will work similiar with any sound source unit ie. Radio Tuner, Tape deck, etc. Just think of it this way, a PRE-AMP is BEFORE the AMPLIFIER, all the AMPLIFIER is going to do is AMPLIFY the sound to your speakers, HOPE THIS HELPS!
Feb 03, 2009 | Audio Players & Recorders
Technics SUV500 Amplifier
check volume balance between right and left-then change inter connection between sound source and amplifier with new cabel(i prefer gold plated type connectors)(see radio shack).
after that if the problem excit your fault in output transistors or output stereo ic depend on circuit design.
Feb 17, 2008 | Technics SUV500 2-Channel Amplifier
No sound output from amp.
It has bad parts. It should NOT be drawing 15amps at idle!! You need to grab a DMM and check the mosfets!!
Sep 20, 2006 | Rockford Fosgate Punch 800a2 Car Audio...
2,779 people viewed this question
