Question about Canon imagePROGRAF IPF710 Printer
How do I clear the error code on my Canon ipf8300 in order to change the print head?
fer_nan_14
  • 76 Answers
SOURCE: Error code 03130031-2F13
03130031-2F13 A/D Converter external trigger output stopped
and the problem is main controler
Posted on Dec 08, 2008
SOURCE: Canon Pixma MP500 error
ok I figured out what to do. Open the over take out all your ink cartriages. Then flip the print head level on the left hand side up and squeeze the top of the print head (where all your ink sits on) and lift it up. You may want to blow off any dust that may be in there and put the peint head back and replace al your ink put the level down and you should be good to go if not you may have to replace the head.
Posted on Jan 01, 2009
johnm329
  • 3 Answers
SOURCE: canon ipf 8000 print head problems
You need to boot the printer into service mode.
Hold down the roll/source button and the info button while you are powering on the machine.
This should get you booted into the service menu where you can then access the replace printhead function
When you have successfully replaced the printhead, reboot the printer to get out of service mode,
You may also want to check the firmware version of your printer and update it.
Updates can be found on the Canon website
Posted on Jan 27, 2009
SOURCE: canon i255 printer--print head error
my cannon printer i255 head has a problem and it should be replaced so i need a printer head of i255, please give the price of printer head
Posted on Jul 08, 2009
  • 79 Answers
SOURCE: I need to change the
you can solve this error code by removing the purge unit (take care of the ink).
Then you have to turn upside down the unit to check the gears. There is a white gear that moves in the ''air''. you have to re adjust the gear to transfer the move normally.
Then the problem dissapears.
Also you have to check if the motor is still moving.
Posted on Jul 20, 2009
I cant print it says I'm out of black link and I just replaced it and it's flashing E 1 6
From http://www.refreshcartridges.co.uk/igloo/clearing-canon-pixma-error-message-e13-e16/
Locate the STOP/RESET/RESUME button on your printer which is represented by a triangle within a circle on the body of your printer and is usually in red, white or black as pictured below. With the reset button located hold it down for at least five seconds and then release it.
Aug 02, 2015 | Canon PIXMA Office Equipment & Supplies
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice...
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
6128_image_6.gif Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "Manual Print Head Alignment."
Sep 10, 2014 | Canon PIXMA Office Equipment & Supplies
Why appears the message error hardware 03800500-2f2f
I would recommend running a print head clean on the printer.
Aug 20, 2014 | Canon imagePROGRAF iPF8300 Inkjet Large...
What cause the Error hardware 03130031-2F49 ?
Problem :
For errors 2618, 2F48, 2F49, 2F50, 2F51, 2F52 randomly occurring please follow the steps below.
Solution :
If the printer has the latest firmware installed (Ver. 1.25 or higher - iPF8300 Series), you only need to do the following:
1. Check if the Status Print or Print INF files indicate which print head experienced the error and replace it.
2. If the specific print head failure cannot be determined, replace both print heads.
NOTE: With the previous low level firmware installed, any printhead damage may have spread to other components. Upgrading to the latest firmware version prevents the other components from being damaged in the future. For the initial failures with the low level firmware, you must replace the other components that would have also failed.
Jun 04, 2014 | Canon imagePROGRAF iPF9000 InkJet Printer
Error code 03130031-4027
I have a problem with the print and scan copy how can i fix can you help me
Nov 27, 2013 | Canon imagePROGRAF iPF8300 Inkjet Large...
Canon iPF 8300: Hardware Error 2F48
Canon have a Technical Bulletin regarding this error (TP11 3337d.pdf). In my experience it starts with E161-403F/E and if you get past this in Service Mode it cannot detect the paper size (the multi-sensor lights on the carriage do not work). After re-seating the flex into the PCB I got the 2F48 error. I think it is related to poor ink flow at some point.
The bulletin recommends (after updating firmware) you:
-Turn printer off
-Remove both heads and dispose of them (Can carriage EEPROM corrupt new heads? $1000 in the bin?) - bulletin states heads MUST NOT BE REUSED so seems like they mean it.
- Replace Carriage PCB - another cost!
- Turn on in Service Mode - WITHOUT HEADS INSTALLED YET
- Turn off (clears errors)
- Turn on in User Mode and install heads as normal
- Check ink is flowing into heads - if not you may well fry another head so you need to get hold of a Syringe Kit to pull it through manually (don't ask me how!)
The bulletin also then - disgracefully I add - goes on to say that if this doesn't work change the Main PCB as if the $2000 outlay to do so was an arbitrary amount of money to pay to get the clearly mal-designed printer to work again!
Good luck anyone reading this, I'm about to do this myself today on my Canon iPF8300S - but before I hook out the Carriage Relay PCB and heads I'm going to connect a new flex from Main PCB to Carriage PCB and hold it in the air while the printer initializes (chasing it through the machine is a ballache if not required). The crushing of the flex by the chain/against plastic mount is far too common - and a known issue since ipf8000 at least and definitely worth a try if more than one head error occurs.
Aug 30, 2013 | Canon Office Equipment & Supplies
Canon Hardware Error 03130031-2F50
My printer just gave that code, and Canon fixed it. It has to do with communication between a head (that code say's right head, is what tech said) and the driver board that is on the carriage.
To fix mine, they replaced the carriage and both heads (because if one went bad, it could take out a new one as well).
Jun 03, 2013 | Canon PRINTER, iPF8300 44 - 3811B007
Pixma mp600 error code u052 ,type of printer head is incorrect. Need to know how to remove & reinstall as pre instructions on page 69 of manual
Got the error U052.....with incorrect print head. Has been printing just before. How do I remove the printhead and place it back in. My printer is Canon MP610
Jul 26, 2008 | Office Equipment & Supplies
My canon mp830
Error code 5200 means the print head temperature is too high. The only was to resolve this error is either replace the print head or replace the logic board. The print head is available, part number QY6-0061 but you will struggle to find a logic board. The only other thing you can try is resetting the EEPROM on the logic board, this sometimes clears the error. A service manual will show you how to do this: http://www.tradebit.com/filedetail.php/4546483-canon-pixma-mp830-printer-service-manual
Jun 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon imagePROGRAF IPF710 Printer Logo
134 people viewed this question
old marine
old marine
