Question about Bauknecht Dishwashers
What does E8 and F1 error codes mean? We get this at the beginning of the cycle and the dishwasher shuts off?
SOURCE: hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
Posted on Feb 23, 2008
SOURCE: smeg code E8
I have exactly same problem. Have you solved it yet..
Posted on Aug 30, 2008
  • 3 Answers
SOURCE: F1 error on the 1 draw dishwasher
I've never found personal ranting to work myself. However F1 is meant to be a flood warning, there's a sensor in the bottom of the drawer unit that stops the dishwasher if water accumulates in the casing, not the drawers!
So the error could be caused by a leaky hose, a broken or fouled lid or a blocked drain hose stopping the drawer from pumping out, at least these are the problems I've heard of or had.
TURN THE POWER OFF BEFORE TRYING THE FOLLOWING.
To see if you have water in the unit you need to remove the lower drawer, to do this open the lower drawer and you'll find the drawer release clips on each side of the drawer in the corner to the front and at the bottom. When doing this always support the front of the drawer in one hand while releasing the clips with the other. To release the clip push it in and slide it back 3-4cm while gently lifting the front of the drawer (don't try to lift it out, you only want to make the clip slide back easier!). Repeat this with each clip.
The drawer is on telescopic side rails, so while supporting the front you need to slide each side back, the clips you released are at the end of each rail and you can slide these easily by feeling just under the edge of the drawer. When they're both slid to the back you should find that the drawer will slide further forward and you can lift it out but don't try and pull it right out because all the hoses and wires are connected, just have a towel or something that you can put on the floor to protect the drawer and leave it there.
You should now be able to see into the base of the unit and see if there's water there. The sensor is attached to the bottom panel in the casing, if there's water puddled here you may have a hose or lid leak, you'll need to dry the casing out (thorougly, probably with a hair dryer before you can clear the F1 error).
On older models the lid motors on either side of the unit (they were white) did have a reputation for breaking, if you see water splashed around the sides it might be one of these that's gone, check for tell-tale signs for leaky hoses too (that would be water where it's not meant to be).
To replace motors and hoses is up to you.
Posted on Oct 14, 2008
  • 423 Answers
SOURCE: le code on ldf6810bb lg dishwasher
The LE error code can mean that the impeller is damaged or there is some debris blocking the the sump area underneath the filter or the wash motor has failed. In that order.
Remove the spray arm and filter (9 phillips screws) - inspect impeller for damage, with flashlight, look everywhere for debris (watch out for broken glass!) Reassemble and test.
If problems continue, schedule as service call focused on the wash pump/motor.
Good Luck!
Posted on Apr 06, 2009
SOURCE: Fisher & Paykel dishwasher:
Turn off dishwasher's circt braker at distribution panel (usaly located in garage or in basement)
1. Open lower drawer
2. Push in two plastic buttons at front lower corners.
3. Remove drawer from railing
4. Remove water from bottom of dishwasher
5. Use hair drier to dry off bottom copartment, specialy in left corner at floding switch location.
6. Install drawer on the rail in position when plastic buttons pup up
Posted on Apr 21, 2009
Where is the distributary valve?
that is a very good question
i cant find a "distributary valve" for sale
lots of water inlet valves hot and cold single units
almost every dishwasher user manual and has code e8 mentioned and faulty distributary valve
why the fault
.If the distributary valve have worked for 150
seconds, and could not reach right
position during wash cycle,after the cycle is finished, the dishwasher will shut off all
loads, the alarm buzzer will ring for 30 seconds and the window will display "E8" at rate
of 1Hz in 30 seconds, and then display "E8" , drain water for 2 minutes meanwhile
May 12, 2016 | Dishwashers
What does fridgidaire dishwasher error code pf mean
Usually the PF code means a power failure. You should check the wiring to the machine for loose wire nuts or wires with missing insulation touching each other or the side of the wiring housing. (You'll need to remove the access panel at the bottom of the dishwasher to check the wiring.)
If the wiring is fine, check the switches in the door latch. The white wires should test fine for continuity. If those switches are fine, then the control board has a wiring fault. Replace the appropriate parts. If your dishwasher is under warranty, contact Frigidaire.
If you add a comment with the model of your dishwasher, I may be able to help you find the replacement parts.
I hope this helps.
Sep 21, 2014 | Dishwashers
F1 Error Code : Kenmore Self-Clean Electric Range. Oven wont shut off. I can silence the F1 alert but it keeps coming right back on every 30 to 60 seconds or so. Range top burners work fine, but oven
An F1 error code usually means that the temperature probe isn't sending the correct signal back to the control board. Try disconnecting power to the range for at least a minute. If F1 displays after you cycle power you may need to replace the EOC (Electronic Oven Control).
Dec 05, 2012 | Ovens
Maytag Bravos error code f1
F1 is a very bad error unfortunately. Try unplugging the unit 60 seconds to see if it will reset the control board. If not, then you will need a new relay control board which is about $200, because F1 means that the board has detected an internal short inside the control board itself.
Apr 24, 2012 | Maytag Bravos MTW6600T Top Load Washer
I keep getting an F1 error code on my whirlpool elite washer at beginning of cycle and at beginning of rinse cycle, why?
F1 error code usually refers to a control board or touch pad failure in a whirlpool washer.
Hope this helps if you have any further questions message me back Thanks Rick
Jul 17, 2011 | Washing Machines
What does f1 mean
The F1 error refers to 'internal flood.'
You may wish to reset the power of the unit, this may clear the error code.
One common cause is too much or 'wrong' detergent causing too many suds. In this case, giving the unit time and a reset is all you need to do.
You may wish to check under the unit to look for a tray with a widget floating in it. If you find such a tray, empty it & cycle the power to reset the F1 error.
I hope that helps.
Mar 14, 2011 | Fisher Dishwashers
How to shut off dishwasher? F1 is flashing on control panel.
Hi now F1 mean that your machine has triggered the flood alarm. there are two reasons this happens-- 1st-- there is a leak on one or both of your drawers. they leak because you might have a hole in one of the hoses or your lid is not shutting properly etc. the 2nd reason is that some water or soap suds escaped from the overflow. now i would like you to turn the machine off at the wall and leave it off for a couple of days to dry it out. then turn it on and use the lower drawer for one cycle. if it does not go F1 then try the top drawer for one cycle and see how it goes. if it continues to flash F1 then reply back for further help. good luck.
Jun 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 Error code on fisher paykel softouch dishwasher
F1 means that water is in your basepan--- you can pull the bottom drawer out and soak up the water with a towel... you will have to use a hair dryer to dry underneath the control sensor in the back left corner.
Apr 11, 2009 | Fisher Dishwashers
Kenmore Oasis HE shuts off during wash cycle and gives F1 error
F1 error means the main control computer board. see other posts in this section as there are many who are complaining about the same problem. buying the new board (revised) will solve the F1 problem, but other problems will soon crop up on this POS washer. if you have the chance to return it to sears, return it immediately!!!!
Mar 10, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Cabrio Washer Error message code F1
Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
Feb 13, 2009 | Whirlpool Washing Machines
Dishwashers Logo
172 people viewed this question
Top Bauknecht Dishwashers Experts
freddyfox
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Bauknecht Dishwasher Expert? Answer questions, earn points and help others
