Question about Bose SoundDock Digital Music System for Apple iPod - White
The power supply of my Bose sounddock series 1 stopped working and the price of a replacement is too high, Can I change the 4 pins connector to a regular 2 pin connector in the sounddock. (I know that the 2 pins on top of the connector are ground and the lower 2 are 18+ and 18- where do I connect the 2 grounds)
    Novelist:
  • 86 Answers
You cannot use a two pin connector as there are three lines, +18, -18 and ground. While you can connect the two ground lines together, you still need to accommodate the split power rails.
The easiest way would be to fit a 3 pin mini-din plug. However, you are going to be looking long and hard to find a replacement power supply on tevshelf that can produce the two rail voltages required at a suitable current.
In the interest of protecting your dock from damage, and given the amount of work required to make the change, you are far better to bite the bullet and purchase a replacement supply from Bose.
Of course, you may be able to source a Chinese clone supply from China on the eBay website - perhaps worth a look... :o)
Posted on Oct 24, 2013
5 Suggested Answers
SOURCE: Bose Sounddock Volume Control Problems
Well, there really was nothing to it.
I let it dry out for the rest of the day and it went back to normal, thankfully.
:) Juliyana.
Posted on Jul 22, 2008
  • 20 Answers
SOURCE: BOSE SOUNDOCK CONNECTRO BROKE
You can't - the repair needs to be done centrally as the company would be at risk if it sold electrical parts to people who aren't qualified to repair such items. Therefore you need to call Bose and have this repaired, however it's quite a common fault so shouldn't cost too much.
Posted on Dec 31, 2008
SOURCE: missing power cable for Bose Sounddock
i did the same thing.... i worked for ccity and when we were closing they were about to throw away the display soooo it found its way 2 my car... there was no power port... call bose and go through the automated bs and tell the customer service rep ur power cable died and u tested "ur friends power cable" and it worked fine... tell them u need both parts and if its like my item it should still b under warrenty and they will ship it for free. if not u can just order the parts.
Posted on Mar 10, 2009
  • 19 Answers
SOURCE: missing power back bose series1 sounddock
If i'm not mistaken you can find those on Bizrate.com.
Posted on Sep 04, 2009
Bose SoundDock Power Supply Pin-outs so I can test one
Hi, The pinouts are as labelled below. The original Bose supply allows for 1A max current, so I would prevent your power supply from going above that.
May 20, 2013 | Bose SoundDock digital music system...
How to replace a fuse on a bose sounddock
Assuming you have a Sounddock Series 1 the Low end Bump -Bump, nine times out of 10, the Bump is the power supply connector inserted in the wrong orientation. Check you have the plug correct. If it is correct then look on www.invebo.com for the diagnostics video.
Feb 28, 2012 | Bose SoundDock Digital Music System for...
I have a BOSE soundock portable and I have to replace my connector at the end of the power supply.What is the size of the connector.
Bose uses a proprietary connector for their power supply. Your best bet would be to purchase one, for example at this site: http://www.frontrowelectronics.com/bose-power-supply-sounddock-series-1-white.aspx?utm_source=googleBase&utm_medium=referal&utm_campaign=Bose
The four pin connector is not standard and cannot be found in stores such as Radio Shack, etc.
Mar 07, 2011 | Bose SoundDock Portable Digital Music...
Bose sounddock seriesII remote will not navigate playlist
EIther the remote is faulty or a broken comms pin on docking connector. www.invebo.com will rpelace the dock connector for you for about 30 Euros.
Apr 16, 2010 | Apple Bose SoundDock Series II Digital...
Our sound dock does not charge our ipod touch 2nd gen. Bose manual says it does charge. The sound dock is not series 2. Are they not compatible? Thanks, Mark
The original SoundDock will not charge the iPod touch 2nd gen, or the iPhone 3G, or the new nano either. This is because Apple changed the way their new iPod products charge. (via USB only now)
There is 1 solution- Call Bose tech support. They can replace the 30 pin metal connector for a new one that will charge this. If this is not under warranty, it will cost $99, but it's worth it. New 1 year warranty, and compatibility with all iPods (except much older- non-clickwheel iPods)
Jun 21, 2009 | Bose SoundDock digital music system...
Bose sound dock doesn't work at all
If this is the original SoundDock, the power supply in back is 4 pronged and a pin could be broken. If it makes a quiet thumping sound, then just make sure the power supply is not plugged in upside down (it's easy enough to do).
If this is the SoundDock II or the SoundDock portable, it's hard to say why this would happen, so you should call Bose on that one. There should be an indicator light that tells you when it has power..
Jun 19, 2009 | Bose SoundDock iPod Digital Music system...
When i plug in my sound docking station it makes a knocking sound
The only 2 possibilities are: 1. The power supply IS bad and needs to be replaced. (not the cord, but the supply itself) 2. The 4-prong power supply plug at the back of the SoundDock isn't connecting properly (try flipping it upside down, or making sure "DC power" is written on top if it's a later version.)
If this is the SoundDock Portable or SoundDock II, then the problem is definitely the supply.
Bose can send a new supply for $50+, or repair a non-warrantied SoundDock for $99.
Jun 13, 2009 | Bose SoundDock Digital Music System for...
Missing power cable for Bose Sounddock
Repair may the only solution. The new power supply is only slightly different though.. If you don't want to spent the $100 to repair this, you could get the new supply and carve a notch in the top part of the square power input.. Looking at the new power supply, the top is a bit taller and arched but the same specs..
But the new power supply is still expensive. (I think $60+) So for an additional $40 ($100 total) you can get a new supply retrofitted on to the old input. It's worth it- you get a new 1 year warranty, and they put the new Apple dock connector on there (USB charge pin) as well as the power supply, so you can use current iPods as well as old. (Your SD currently won't support- iPhone 3G, iPod Touch 2ng gen, or iPod Nano 4th gen.. it will after a repair)
May 17, 2009 | Bose SoundDock iPod Digital Music system...
Bose Sounddock problem
I had the same issue, it just stopped working today for no reason. Since it's out of Warranty and Bose charges too much to fix it, I took the bottom off, cleaned all the contacts, applied some dialectric silicone compound to the contacts, put it back together... and it works great!
Sep 17, 2008 | Bose SoundDock digital music system...
Bose SoundDock Digital Music System for Apple iPod - White Logo
252 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
