Question about Paradigm CC-350 Speaker
Blown paradigm tweeter - Paradigm CC-350 Speaker
2 Suggested Answers
  • 652 Answers
SOURCE: Paradigm Monitor 9 v4 tweeter not working.
speaker is must likely blown. check to see if another tweeter works at that connection.
Posted on Feb 14, 2010
Have 2 jbl 615 get good base and sub but neither tweeter playing
You will need to determine if it's the amplifiers or the tweeter themselves that are not working. If you open up the cabinets and check each tweeter with an ohm meter for continuity it will show if the tweeters are working, in which case the amp is the problem. if the meter shows that the tweeters are blown, you should still hook up another tweeter or speaker to the horn amp to see if it's blown and therefor took out the tweeters.
If any of this sounds complicated, you'd be best off taking the cabinets to the repair shop.
Mar 16, 2015 | JBL Audio Players & Recorders
I have a pair of Paradigm Monitor 3 V.2 High Def speakers for my front L&R home theater system. On speaker sounds very tinny with no bottom end. On inspection neither the main or tweeter loo
A few questions to help me help you: (1) Does the woofer cone move freely when you use your hands to move it (or do you feel friction)? (2) have you tried swapping the left speaker for the right to rule out the receiver as a cause?
Nov 17, 2014 | Paradigm MONITOR 3 Speaker
How to Replace a paradigm monitor 9 v6 driver
Are you having trouble removing the driver? Just remove it and replace, keeping track of where the positive (red) terminal is and what cable is connected there. The part number should be printed on the back of the magnet.
Jun 11, 2014 | Paradigm Monitor 9 Speaker
Our ten year old paradigm ps 1200 subwoofer does not power up, although it is plugged in and properly connected to the receiver. Why is this? Is it a lost cause?
Disconnect the power, pull the amplifier out by undoing the screws that hold it in.
When you pull it out, look closely towards the top there is a little 1.8A fuse. It probably has blown.
Replace that and you should be back in business.
Sep 20, 2010 | Paradigm PS 1200 Speaker
Feb 14, 2010 | Paradigm Monitor 9 Speaker
I get no music out of the tweeter
Connect the wires of the speaker to a 1.5 volt battery. Plus wire to plus terminal of the battery etc... Only let it touch the battery for a short time! You should hear a pop from the speaker! Put your ear close to the tweeter and see if does the same. If It doesn't, go inside the speaker and connect the battery direct to the tweeter (disconnect it from the crossover unit that feeds it). If it still doesn't pop it's gone and you will need to replace it. If it does it's the crossover that is faulty.
Tweeters are the first to go when the amp is at high volume. So make certain that the speakers don't have a lower wattage than the amp. If they have you must never turn up the volume very high or you will lose the speaker again.
Jan 31, 2010 | Paradigm Titan Speaker
My speakers sound flat with no highs at all
I am trying to work out if you have damaged the speakers and amp too.
Have you tried a pair of headphones on the amp? If they sound ok then your amp is fine.
Assuming it is, then speakers have what's called crossover units in side each of them. This splits the sound into three parts. Bass, midrange, treble. The bass is handled by the woofer's, the midrange by a middle sized speaker or or it's combined with a tweeter, which of course handles the treble.
Connecting a 1.5 volt battery across any of the individual speakers will cause it to pop if working. If the speaker then is not getting sound then the crossover unit is to blame.
When you look at the crossover unit, it will have coils and capacitors (non polarised) on it. The bigger ones deal with the bass and the smaller ones treble. If you find a fault say on the crossover of the speaker, for example no treble comes out of it. Then start by replacing the capacitors. Use the same value as on the capacitor and remember they fit any way round.
Apr 14, 2017 | Paradigm Audio Players & Recorders
Paradigm CC-350 Speaker Logo
29 people viewed this question
Top Paradigm Audio Players & Recorders Experts
 Grubhead
Grubhead
woodzowl307
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
