I need to remove the inverter to send it off for repair. I've removed the monitor's base (stand) and the screws around the back of the case but the case won't pull apart. I believe there are hidden clips around the edge. How do I locate and release them without breaking them or marring the plastic?
Thanks
This is for a Viewsonic VX900. The bottom bezel with the button unclips.Unplug the connector, and put aside. ( Dont pull on the wires) Then there are two screws that are removed, and the grey frame around the monitor comes off next. Then remove the 4 bottom screws, and the two top tiny screws and the LCD comes away from the back. Remove the shielding, and replace your components. Good Luck !!
not sure what you are attempting, but.
just the bottom base stand off that it.???
it came new with base attached, so, that means total disassembly, worse case.
the back will need to come off, to get to base mounts
there is no service manual or google showing any other person asking this . The screws can be hidden under caps on the rear.
This tip will explain how to open the case on most LCD monitors. Most monitors will eventually have a problem with the power supply and need servicing. The part most people have difficulty with is opening the case to get to the electronics. You will need a phillips screw driver and a small flat blade screwdrivers. You will first need to remove the stand, place a bath towel on a flat table, lay the monitor down and unscrew the screws holding the base and remove. Next you will need to remove any screws that are holding the back plastic case on, they will normally be in the 4 corners and possibly 1 in the bottom center of the back. Now take the small flat blade screwdriver and insert it between the two halves of the case in the center of the bottom. Be sure to not do this by the control panel so you don't break it. Gently pry the two halves apart. Most monitors will have several plastic latches around the perimeter of the case, usually 2 on each side that will need to be released. As you separate the case halves the latches will release and the back will separate from the front. You will need to unplug the control panel cable at this time before you can get to the electronics. Now you just need to use the phillips screwdriver and remove the metal shield from the electronics to get to the power supply. See pictures below.
Now release the catches as seen below:
Detailed monitor breakdown and repair information can be found on our web site at www.ccl-la.com
The HP is a flat screen monitor used with many desktop computers. When the LCD on your HP monitor goes white, it is an indication that your monitor's inverter board has gone bad. The inverter board is a small circuit board that transfers power from the monitor's main circuit board to the LCD screen. Replacing the inverter board means dismantling the HP monitor.
1. Power down your computer and unplug the HP monitor cable from the back of your desktop. Disconnect the power cable from the back of the monitor. Relocate the monitor to a flat work surface. Place the monitor with the screen facing downward.
2. Remove the Phillips-head screws from the monitor's base stand and from the back cover. Lift the base stand off of the monitor and remove the back cover. Peel away the foil from inside the monitor around the internal circuit board.
3. Locate the inverter board near the bottom of the monitor's casing. Unplug the power cables from either side of the inverter. Loosen the Phillips-head screws from the inverter board. Lift the old inverter out of the monitor's casing and set it aside.
4. Place the new inverter inside the monitor. Replace the Phillips-head screws and fasten it in place. Reconnect the power cables to the connectors on each side of the new inverter. Replace the foil around the outside of the main circuit board.
5. Replace the back panel and base stand, and their retaining Phillips-head screws
I hope you find it very helpful. Thank you for choosing fixya.com
Not sure if you will find one... Process on toshibas is:
Pop top cover (sometimes also secured with a few screws on side or bottom of laptop) near monitor base above keyboard to access LCD cable and mount screws
Unplug cable and remove monitor mounting screws (Under plate, on back where cables plugin, and sometimes on bottom)
Take monitor (on flat surface) and remove screw covers with needle so you can put them back on later.
Remove all screws
Use plastic credit card and run around outside lip of screen case until removed
Remove LCD mounting screws
Remove LCD and inverter
Remove LCD brackets and inverter from panel
Replace panel and start working backwords.
chrisc257, Yes, you too, will need to watch some video clips @YOUTUBE !!! Search and view 6 to 10minute clips of "LCD monitor disassembly" and "LCD monitor repair" and stuff relating to "bad capacitors in lcd monitors" . Are you doing this as a SCHOOL SCIENCE PROJECT that you will be graded on? First remove the pedestal stand from the back cover.(screws or some locking TABS) Then remove screws from back cover. If you can see them. then un-snap the cover from the front bezel. Watch how they do it on youtube and be careful not to injure yourself or the monitor LCD panel.. GOOD LUCK GUY, YOU'RE ON YOU'RE OWN NOW!! 12fixlouie
First, lay the tv/monitor on its screen on something level and soft as not to damage the screen. Remove any visible screws that seem to attach the base to the unit. Some models you have to look under the base for pins orso to push together to slide the base from the stand, only then you could reach the 1 screw holding the monitor to the stand....Once stand removed, remove any screws you see holding the monitor casing together, usually only a few screws since they are mostly held together by plastic "clips"...Once screws are removed, then gently insert a flat(screwdriver orso) inbetween the case?housing, repeat this all the way around the case/housing till completely loose....You will prob have a few wires or maybe a ground wire that you would have to remove before completely being able to seperate both sides(front case, back case)..Sometimes you might have to unscrew and remove the skinny washer/nut around the cable input orso..
take cover off top of base.- pry off remove two screws that hold speaker unit, it will tilt out, disconnect cables and remove speaker. two screws on back of base and then take off back cover.remove sheild cover. disconnect all cables. 4 screws hold power supply in. rca connector board has little black button holding it on. pry up and then remove board to access connecters behind. pull all cables out towards you. remove 6 screws that hold base to back of screen, pull up tape under where cables go thru hole. remove base from screen. take out screws on back of screen. carefully pry all around case to seperate. remove back, and then sheild. there are a few screws that hold it on. If your screen was black, then the two inverter boards could be the problem. there is one in the upper left corner and one in the lower left corner. you can by them on internet. match the partnumber, there are 2 diffent ones.
Since you have surely looked, it isn't held on with exposed screws.
Check to make sure that the rounded area that allows tilting is not part of the case but appears to be separable.
Most that are removable are held by a tongue and a fairly obvious release tab.
if you can't remove the base, just place the monitor in the carton on good padding and upside down.
Fill and cushion the sides well, mark the carton with 'This side up' and an arrow and hope there are no malicious handlers on the trip.
I've shipped numerous monitors of different sizes and types and have lost none of them to shipping damage.
1- Remove the four screws in the back of the monitor. Two are in the bottom corners and two more near the bottom center ( these hold the stand in place). 2- Remove the stand. 3-The case back is held on by the four screws and a number of plastic pressure clips. After removing the screws: using a fairly wide flat bladed screw driver; insert the blade in either of the two slots on the bottom edge of the case and twist with medium force. This begins the seperation of the back from the rest of the monitor. As the crack widens, begin moving the blade of the screw driver along the widening crack (around the case edge) and twisting gently. This releases each pressure clip in turn. Separate the case back from the rest of the monitor.
I did this this way with my monitor. It works. Good luck.
