Question about Kitchen Appliances - Others
Instructions for breville brita vkj367 - Kitchen Appliances - Others
Today I bought a Brita FF-100 Black & Crome model. There was no green light flash after I inserted the cartridge. I don't if it's safe drinking or not.
This type of unit may have a battery that has a plastic tab that has to be pulled out so the battery makes contact. Did you read the instructions?
Brita FF 100 Google Search
Nov 24, 2016 | Office Equipment & Supplies
Where can I find a replacement filter spout?
About 683,000 results (0.79 seconds) Search Results
    Buy Kettle Spare Parts ' Calcium filters, Lids and More ...
    www.espares.co.uk/browse/at1102/kettles/small-appliances
    Buy spares for your kettle; kettle filters, kettle lids, kettle descalers and more. We carry parts for all home and garden appliances. ... Find Kettle Spares. Black & Decker. Bosch. Braun. Breville. Brita ... Kettle Spout Filter. Genuine spare part for ...
Feb 05, 2016 | Kitchen Appliances - Others
Why does my single cup coffee brewer make loud noises?
it like every thing it needs a bath have you cleaned where the coffee pack goes have you ran any vinegar through 4 or 5 brews try this and then run water through it 4-5 times and don't use tap water through it use filtered water like one of those Brita filtered water pitcher makes coffee taste better also. if you still have your manual
it will tell you how to keep it working great if not get model number off back or bottom and look it up on the web GOOGLE it!! enjoy !
Oct 18, 2014 | Breville Coffee Makers & Espresso Machines
Vkj476 BReville hot cup with variable dispense. How do you change the filted britta filter
The Breville VKJ476 Hot Cup with Variable Dispenser does not require a filter so will not take a Brita filter.
Mar 21, 2013 | Breville Hot Cup With Variable Dispenser...
No lights or boil
I would test the thermo fuse, power switch, and the AC cord. You will need the proper connectors, crimp tool, and replacement parts.
Jerry G.
Jun 21, 2012 | Brita Breville White Filter Kettle Model...
I need user guide for a breville cm9 cappuccino
i need instructions on how to use cappuccino maker breville cm9
Apr 04, 2010 | Breville Coffee Makers & Espresso Machines
I would like to buy a breville cappuccino maker but hear the dial at side gets stuck and breaks easily,even when cleaned well after use. Has this been rectified. Doreen
Hi, apparently Brita, that owns Breville, did not fix the problem yet.
I can see that complains keep coming.
The problem is apparently on CM8 and CM9, the more expensive Cappuccino Maker BES200XL
does not have the problem.
One suggestion, Breville are nice budget coffe maker, if you want to spend some mor money on a better product buy a Gaggia or something similar. Italian coffee makers are usually the best for espresso/capuccino. If you want a Breville buy the ESP8XL Espresso Machine.
Here is another good brand.
Sep 13, 2008 | Microwave Ovens
Can't find a replacement filter
Try Brita or Aqua Optima filters
Aug 21, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
