Question about Pool & Spa
Algae dust in pool - Pool & Spa
  • 1,631 Answers
I think Brandon's answer deserves a little more time and a slight explanation... as I think it is Spot On!
Algae dust is usually "Already DEAD" algae!
And normally it is way to Small & Fine to be trapped by the filter.
We here on this forum do not know what type of filter you have, But if you do have a "MultiPort" valve as Brandon suggested you turn to the "Waste" mode, you will not use the filter mode to vacuum, as this will only BLOW the Fine Silt like substance right back into your pool, spreading out into the water to be suspended turning your water cloudy if not green, until it settles, and once again you have a covering of Dead Algae Dust on the floor of your pool. But when the filter valve is in Waste mode, you will bypass the filter and the return line altogether and your vacuumed algae silt will be sucked up into the valve, and OUT the valve to waste. And just like that all of the algae dust is vacuumed out and did not Blow back into your pool.
I just had a situation where we cleaned up such a pool where the customer couldn't get the algae out, we came out and vacuumed to waste. And I by chance took a picture of the partially vacuumed pool and Dust remaining.
Algae dust in pool - algae-dust-in-pool-iwrnrkacomuoeuyhvucmvd0t-2-0.jpg If you don't have a multipart valve, then if the pool has no debris but only dust, then and ONLY then, should you use Backwash mode. You NEVER want to vacuum a pool with debris in Backwash mode! NEVER!!! Because the larger debris you are vacuuming will get caught in the internals of your lateral drain assembly or your DE Grids. then it will be very difficult to un clog them, which in turn will reduce proper water filtration efficiency! But the algae dust will be able to pass right on thru. If you have neither of these types of filters because you have a Cartridge style filer, the elements may be able to trap the dust, if it is still to fine to filter, you obtain an additional pool pump, place it pool side, and in the pump out the pump will be two vacuum hoses and away you go.
Good Luck
Posted on Apr 05, 2015
  • 112 Answers
The above answer is very helpful but I would like to add that if the water is clear and there is algae growing on the floor you can vacuum this with the multi-port valve on top of the filter set to waste. Ensure that the valve on the waste line is open. this will cause less cloudiness by brushing and allow for your pool to stay clear.
theswimtimeonline.com
Posted on Mar 20, 2015
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,448 Answers
Make sure chemicals are in balance then super shock pool like 10 x then brush entire pool it will be gone also clean filters or backwash
Posted on Oct 15, 2014
Pentair tagelus t60d filter filtering algae back into pool
Have you backwashed the unit? That would clean out remaining algae.
Jun 18, 2014 | Pentair Tagelus TA 60D Filter
Hi I have ab 18x52' intex above ground pool with klear saltwater system, but I have algae in the bottom of the pool, please tell what to do to clean it without emptying the pool, and can i use any...
Get ready for a full weekend of cleaning your pool :) This is the chemical free method...
1st... Start with a clean filter...So clean your filter...
2nd.. Vacuum your pool and get most of the algae up from the bottom and sides.. Go slow so you do not stir up the algae. Make sure you use the vacuum attachment with brushes..
3rd..Clean your filter...
4th...repeat step 2 again...
5th... Clean your filter...
6th... Brush your pool with a pool brush to loosen the remaining algae..
7th... Set your pump timer for 12 hrs and your chlorinator for 10 to 11 of those hrs... and run for 3 days...
8th.. Check your water and see if has cleared and the algae is almost completely gone.. If so, check your free chlorine level and adjust your cycle down if at the required level..
9th.. if your chlorine level is not at optimal, run at the 12 hr cycle for 3 more days and check..
10th.. After water is clear and free of algae, clean your filter and adjust your cycle down to control your free chlorine level...
Good luck and hope this method works for you.. It has for me for over 2 years with my Intex Salt Water system...
Please take the time to rate me and write a comment... really appreciate!!!
Aug 03, 2011 | Intex Automatic Salt Water System for ...
Should my main drain valve be open or closed?
iuf youre just opening and pools Green ? then Yes you want to pull the algae dust Dwn to bottom.. So you can vacum to waste ..Sand cannot filter algae particles it will just come thru the returns you can view it ...
Jun 04, 2011 | Hayward SAND FILTER, PRO SERIES
We changed our pool over to salt water four days ago ago and it is cloudy and has green algae in it. It had green algae when we switched. We thought the salt water system would kill it, but it is still...
You don't mention the size of the pool. If this is a above ground small pool ... dump the water, clean the liner and refill it. Remove the metal with a sequestering agent. Get the alkalinity correct. Get the pH correct then add the salt to 3200 ppm.
Chlorine kills algae. Are you sure it is algae and not metal in the water?
pH should be 7.2 to 7.6. Alkalinity should be 100. If a gunnite pool, the calcium should be 300. Salt should be 3200. Cyanuratic acid should be 50+ if this pool is outside (not indoors).
What to do. If this is a big pool, and you are sure this is not metal in the water, I would super chlorinate the pool - take it to 20 or so ppm. Run the filter for at least 24 hours. Watch the pressure ... you will be filtering out a lot of stuff.
Let me know what happens ...
Thanks for your question @ FixYa.com
May 24, 2011 | Intex Automatic Salt Water System for ...
The water is clear but I have green algae on the bottom of the pool. How do I get rid of the algae? Do I use a chemical algaecide?
Super CL your pool ... take it to 20 PPM and let the pump run ... brush your pool with a nylon pool brush.
Aug 13, 2010 | Intex Automatic Salt Water System for ...
I have a salt water pool and after 3 months it is developing black spots and lines on the bottom and progressing up the sides............I suspect this is an algae..........What would be the remedy for...
Drain the pool get in and TOTALLY scrub all of the fungus & algae off with bleach, (Or it WILL come back quicker) then treat areas with algae killer, and then rinse out all gunk, clean spotlessly, and then refill, and from then on, make sure you use a commercial algae preventative, also up the refresh rate of water exchange.
Aug 11, 2010 | Intex Pool & Spa
Why did my pool turn green shortly after start up?
The question is what the green is... If you see the presence of Algae in the pool, then you need to treat for removal of Algae. This can be prevented in the future by keeping your Chlorine level at or above 1 part per million. If your water color is a green tint but no algae present, you may have a high copper content in the water or some other mineral present. You will need to use a Metal out product soon to prevent staining, especially if your pool is plaster. If you have a pool heater, make sure the chlor gen was installed in the plumbing AFTER the heater. Seek professional assistance from a local pool professional with salt system experience if you are unable to resolve this to prevent system wide complications.
Apr 14, 2010 | Intex Automatic Salt Water System for ...
Light brown algae(?), small 2 leafed clover growing in pool.
add a clarifier this will make particles bigger and will be more managable either through filter or vac
Jun 13, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Pool & Spa Logo
684 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
