Question about Gateway NE56R13u Laptop
NE56r won't boot past the Gateway Screen flips back in contininous loop Won't boot from any source either
  • 81 Answers
SOURCE: I have a gateway laptop that won't boot up. Only
try checking out to see if maybe you have a bad memory inside first. then if thats not the problem im gonna have to figure your hard drive might be going bad because of corrupt files and fragments.
Posted on May 27, 2011
SOURCE: my gateway 4540GZ won't boot up when I turn it on
Disable other bios setup and enable only the hard-disk.The procedure is these:put on your machine for the first time immediately press (F2) button.if it refuse to display off your machine and restart Then immediately press (F9). when it display the setup locate and select boot menu it will display all the booting function such as: CD/DVD RW, HARDDISK,ADAPTER AND SO ON just select each one it will show two options:ENABLE/DISABLE. you just select disable for others except HARDDISK should be ENABLE.finally,close it and apply save& exit.restart your computer it will definitely boot up.
Posted on Nov 24, 2011
Geekman
  • 32281 Answers
SOURCE: Screen to gateway NV59 won't turn on
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Mar 26, 2012
  • 6771 Answers
SOURCE: gateway lt2032u won't boot
Did you use a static mat or band to discharge any electrical activity out of the body, if not you probably had a static buildup and discharged it on the main board causing a disruption in the data flow, you may need to re-install your operational system.
Posted on Mar 27, 2012
tennysony737
  • 49 Answers
SOURCE: Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Posted on Sep 18, 2012
Gateway NE56R
1. Flip your unit over to its back and remove the battery.
2. Remove the screws on the large cover and remove the cover.
3. You will find the memory and hard drive under that cover.
P.S you should use a static guard to remove any of those parts.
Hope this helps
Feb 18, 2013 | Gateway NE56R Dual Core 2.10GHz 4GB 320GB...
I bought a new laptop Acer Gateway NE56R. When i start the laptop, it is taking to some page to view the licence for Linpus. If i don't view the conditions, the laptop is shut down after 15 minutes. If...
If the unit is new under warranty return it to where you purchased it.
If not and you do not need Linpus on your unit, boot into safe mode and run a msconfig.
Put a check mark next to the application which you no longer want to load.
Restart your unit and see if you can navigate into windows.
Hope this has helped you.
Jan 31, 2013 | Gateway NE56R Dual Core 2.10GHz 4GB 320GB...
Gateway 3522 laptop won't boot up
HDD problem, try to fix boot record and test HDD with Hierens Boot CD
Nov 13, 2012 | Gateway 3522GZ Notebook
Hp pavilion dv9000 takes a long time to get past the bios screen. It won't boot of dvd either??
Check BIOS boot options and assign local hard drive as first for faster boot. This is also where you set CD\DVD as first to boot from disc. Look for F Key press on start up. It will be shown on screen. These can vary.
Many HP machines also have a boot menu option during boot. Again an F key and may vary.
Sep 22, 2012 | HP Pavilion dv9000z Notebook
Somehow your MBR (Master Boot Record) likely got corrupted or possibly your hard drive went bad coincidentally.
Simply, you will start your computer from your Windows CD/DVD install disk, then when at a DOS prompt ( D:\ ) you will then type: FDISK /MBR (press enter).
Find your Operating System install DVD and start your computer with it, then follow instructions within this discussion:
Restore Windows XP MBR without Windows XP disc
Alternatively, review my search results for other instructions:
fdisk mbr windows xp Google Search
Nov 22, 2017 | Gateway MP8708 Notebook
Aug 25, 2012 | Gateway MP8708 Notebook
Won't get past gateway screen
try restart with pressing F8 while powering on that should take you to SAFE mode and then you can find out if operating system is still alive
May 22, 2012 | Gateway CX2619 PC Notebook
Gateway GM5442 PC Desktop Won't Boot!
3 BEEPS -RAM
Guest Posts: n/a 01-24-2005 We had a power failure in the office this weekend. All the systems are back
up and running fine, except for the receptionists. It's a Gateway
Professional Series. P4 1.3 Ghz. It is giving me three beeps. No boot up
screen and no video source (monitor light stays yellow instead of turning
green). I looked up the beep code and it says three beeps means the ram
needs reseated. Which I have done several times. Also, I have just put in
one stick in difference seats. I have also reseated all the cards at least
three times. I have switched the jumper to try to boot into setup mode.
Nothing there either. Popped out the cmos battery and put it back in. No
good either.
Has all the ram been fried? The fan on the cpu is still spinning. The cd-rom
ejects. I can't hear the hard drive spinning. I guess I can swap the hard
drive for a different one.
Anything I'm missing? YEP
http://support.gateway.com/s/MOTHERBD/INTEL/m00262/beepcode.shtml
Apr 06, 2012 | Gateway GM5442 PC Desktop
Mar 26, 2012 | Gateway Computers & Internet
May 27, 2011 | Gateway Laptop with Intel Centrino...
Gateway NE56R13u Laptop Logo
301 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
