Indesit f12 wie 107 - Washing Machines
3 Suggested Answers
SOURCE: Indesit WIE 147 - Display 'F-03' fault
Indesit washing machine error code 3 (F03) On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Posted on Nov 16, 2008
blueextc3221
  • 15935 Answers
SOURCE: indesit washing macine displaying error code F-11
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Why does my indesit WIE 107 display f04
the pressure switch is jammed on empty. this could be either a faulty pressure switch, blocked pressure hose (pull off small hose and blow down to clear any debris) or a blocked sump hose ( big black hose at the bottom of appliance)
Aug 03, 2014 | Indesit Washing Machines
Indesit wie 147 F-12
F12 indicates a communication error between boards.
Check all connections to the boards.
Jan 16, 2010 | Indesit Washing Machines
I have an indesit WIE 137S. When the door is closed, teh red door lock light does not come on and the wash can't proceed. Any hep greatly appreciated
Have you checked your plug and the connections, also your socket.
If no joy, then door lock probably faulty.
Nov 18, 2008 | Indesit Washing Machines
Feb 10, 2008 | Indesit W 123 Front Load Washer
Indesit machine won't start
on the bottom of the machine there is a panel made of plastic that may be removed to expose the waste filter.open the waste filter and check that the waste pump is not blocked as in the initial start up the pump is run if there is a problem with the pump the machine will not advance.
Jul 17, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
