Question about Troy Bilt 25HP VTwin Hydrostatic 50" Zero Turn Radius Mower
Torybult,lawn tractor ,pony willnot go slowto cutt grass
4 Suggested Answers
  • 8404 Answers
SOURCE: I have a troy bilt 42 inch 17 hp lawn tractor. The
One or more of your drive belts is in need of adjustment or replacement, maybe. Possibly, your electric (or manual) PTO clutch could also be adjusted. You do have the spring tensioner on the deck engaged, right? You say the engine doesn't bog when this happens so I am inclined to think "clutch" and/or "PTO belt" to the deck and/or the "deck tensioner" are the things to check.
The tensioner will be the easiest, it is a handle on the left side ON the deck. Has a BIG spring on it. Make sure it is engaged.
Is yours a Troy Bilt manufactured in Troy New York or is it another manufacturer (MTD?). Troy Bilt is actually out of business, having sold the Troy name to a variety of makers depending on the model line. I don't have the run down on who makes what any more (tillers, chippers, mowers, blowers, trimmers, etc.), but Troy Bilt of Troy, NY is no more. :-(
I have a 16 HP Troy with 42 inch deck driven through a electric clutch. I also have a "grass pump" on my deck. Important maintenance tips: Keep the bearings greased, keep the deck clean underneath. The belt on the deck should have the tensioner released when you are NOT mowing. Keep the blades sharp and in good repair. Mow with engine at full speed. When you get to areas of heavy growth, slow the tractor down (hydro drive) or reduce to a lower gear (gear drive). NEVER adjust speed using the "clutch" (hydro drive or gear drive). When you engage the blades (electric or manual) always have the engine just above idle, bring the engine speed up slowly to preserve the belts and reduce stress on all components.
I am sure this is the fix for your trouble. If there is anything else or if I missed the ball, please let me know and we will go further.
Thanks for your question @ FixYa.com
Posted on May 30, 2011
SOURCE: How do I get a manual for Troy Built Pony Lawn Tractor Model # 13AN77TG766
Did you try Troy Built web site or E.Mail them?
Posted on Jun 12, 2012
  • 6468 Answers
SOURCE: How can I get a manual or schematic for Troy Buily Pony Lawn Tractor
i don't have a manual but it sounds like the center pulley is stuck the center of the center pulley should move and change sizes with tension
On my trroy-bilt lawn tractor pony i was in high grass it seem to stop cutting smoke came from the deck stop cutting the handle that engage the blade become reaaly easy to move nothing happened
It sounds like you got into a job that was too big for the machine, and you may have either burned up the drive belt, or toasted the transmission or clutch.
Someone knowledgeable about such things should be able to raise it up in the air and look underneath and discover which problem you have.
God bless your efforts.
Jul 08, 2016 | Garden
I have a craftman riding mower model 917-273381, It will run & cutt grass good for about 4 to 5 min & then stop. I`ve replaced carb kit & check the kill switch. It still doing the same thing.
How long does it have to sit before it starts again? Does it need to be jumped? If battery is old or not recharging you can loose power. I had a regulator go bad and mine would keep dying. I would charge the battery and mow for awhile then would die again. Have you checked battery and regulator?
Sep 07, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
17.5 HP 31D707-0232E1 Briggs & Stratton on my Troy-Bilt Pony lawn tractor had gas in the oild when I drained it to do an oil change. After draining and changing the oil when I started it up it blew...
Either through the inlet valve stem seal, or the needle in the carb is leaking, start by fitting an inline fuel tap so there is no chance of fuel leaking when the machine is stood.
Sep 29, 2012 | Garden
I can't push my toro pony lawn tractor out of my shed is there a release lever for the ****** if not how can i make it possible to push
on the rear of the mower near the tow hook there is a rod with a loop on it pull it out and move it to the side or down to lock it
Apr 17, 2012 | Garden
Change blades on a lawn tractor pony? troy built
just jack it up so you can get under the deck and unscrew the bolt on center of ech blade take note on how the curves of blade are angled do one at a time incase you forget but bolt back up tight and you are ready to cut if you try to resharpen the blades make sure you balance them or they will mess up the deck bearings
Nov 02, 2010 | Troy Garden
How to put together a black n decker grass trimmer,has assembled the trimmer it's not cutting the grass should there be a blade in the trimmer
No, it is not heavy duty enough to drive a blade. It should have cuttting line in it and it only can use up to .065" string (factory recommended).
Oct 12, 2010 | Black & Decker 14" Grass Hog Xp...
My 2008 Troy Bilt Pony lawn tractor will not engage in iether forward or reverse. No clear reason just stopped working. The transmission locks up and the tract or will not start either (probably because it...
Make sure the brake pedal is fully depressing. Check the linkages for the forward / reverse and brake pedal. Check for grass build up causing the linkages to bind.
Nov 26, 2017 | Garden
Troy Bilt 25HP VTwin Hydrostatic 50" Zero Turn Radius Mower Logo
18 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
