Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Were reed valve on a white 31cc weed eater - Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Healeyman
  • 1198 Answers
SOURCE: ryobi weed eater will only run if i hold the choke down
Mine won't spin up till it is good and warm. Check the end of the fuel line in the gas tank to see if it is clogged or dirty or slimey. Make sure the end has not fallen off.
Posted on Apr 30, 2009
  • 323 Answers
SOURCE: do you use mixed gas for a ryobi weed eater??
Unless it has a tag or decal on it saying it is a 4 cycle then it uses mixed gas/oil at about a 50:1 ratio. Straight gasoline will freeze the piston in the cylinder in mere minutes.
Posted on May 23, 2009
carlsbiz
  • 1124 Answers
SOURCE: weed eater stalling
Need to get the carb rebuilt..
Posted on Jul 14, 2009
canbruce75
  • 1776 Answers
SOURCE: I have a ryoby 31cc weed eater I need a diagrm on
Typical fuel line routing2.gif is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Posted on Sep 25, 2009
  • 168 Answers
SOURCE: i have a 31 cc ryobi weed eater start for about
I think a new carburetor kit and a good carburetor tune up is in order my friend. Sounds like it's starving for gas. If it bogs down after warm up when you throttle it, then yes it needs a carb tuning. The L screw is the low side screw and should be turned in lightly until it seats then back it out one and quarter turns (1 1/4). The H screw is your high speed screw. Also, turn it in lightly until it seats, then back it out approximately a 3/4 turn. With these settings the unit should start and may even stay running. Again, if it bogs when throttled, while running turn the L screw out a little more maybe only 1/16th of a turn and then try it again. If it does rev then you'll have to adjust the H screw in about a 1/16th of a turn. But make sure you only do this after the engine has warmed up.
Hope this works, good luck
Skidooer
Posted on Oct 03, 2009
Testimonial: "i,ll try this thanks a lot "
HOW TO REPLACE DUAL LINE ON GRASS TRIMMER
search google for "YARD MACHINE 31CC GAS TRIMMER Manual". the manual is there I have seen it. also check youtube.com
Hope this helps...
May 01, 2016 | Yard Machines Garden
Poulan problems
Poulan Pro Weed Eater. 31cc PPB200E, Crancks good, runs as Long keep chock on , New Carberater, New fuel lines, New fuel filter
Jan 07, 2014 | Garden
How do you fix a poor compression
Rebuild the engine with new parts.
Apr 22, 2012 | Stihl FS 85 Weed Eater
Sparkplug gap for a 31cc ryobi weed eater
If its a 725r ryobi weed eater it takes a champion RDJ7Y with
a gap of 0.020 in. or (0.5mm) with a feeler gauge.
torque @ 110-120 in.lbs. good luck!
Jun 28, 2011 | Garden
Bought new e3 plugs for weedeaters and cant find gaps for them i have a Featherlite 20cc Fl20 and a Ryobi 31cc 700R
The gap for the Weed Eater 20cc engine can be set @ .025". The larger engine Ryobi 31cc/32cc class can be set @ .030" Either engine would operate within that .005" range and I know a 32cc Poulan calls for a .030" gap.
Jul 09, 2010 | Garden
2009 31cc toro weed eater wont stay running. will fire and run at idle but wont stay running in 1,2,3 settings
get a can of starter fluid and a helper. Start the weed eater and then squirt enough starter fluid into the air intake to keep it running while you move it through the settings. This will rid your tool of the crud that is causing your problem. Joe
May 07, 2010 | Garden
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
23 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
