SOURCE: Lines across screen
Is it sort of rolling almost.
If so you have a few bad capacitors in the power supply that need to be replaced.
If you dare to venture inside you should see 1 or more buldging caps. (bowing upwards on the top)
If these start to fail, then they will interupt the correct flow of power and cause this problem with your panel.
Easy to fix if you are electronically minded, if not, take it to your local TV tech and it shouln't cost that much to have repaired.
Remember, inside these monitors is high voltage that can kill, even if it's not plugged in.
SOURCE: Shadow Lines Across Screen on Dell P1130 CRT Monitor
What sort of shadow lines? I assume you haven't just noticed the two horizontal lines 1/3rd up the screen from the bottom and 1/3rd down from the top from the internal stabilizing wires that all Trinitron CRTs have?
SOURCE: Horizontal ghost lines across screen
Seems that it is an issue with your video card, Please update Driver for Video card and it that does not help, it is the time to replace the Video card.
You can get your driver from support.dell.com and please enter your service tag to download the driver
SOURCE: Monitor has many horizontal lines flashing across the screen
Yes your monitor can be fixed by an electronical expert! Is not so big problem but you can do nothing without an expert! The fixing-cost is not much! Is just sync problem! If this help you, rate me! Thx.
