Question about Whirlpool Refrigerators
WHIRPOOL ARC 4030 IX : DOESNT START, (TIK- TAK NOISE ONLY AT THE BOTTOM ( COMPRESOR S PCB )
4 Suggested Answers
SOURCE: Streeing Noise
Fluid new and clean.? Flush system and use correct fluid. Hard steering-- Bad steering rack or strut bearings/bushings on top of towers
Posted on Sep 28, 2009
  • 5317 Answers
SOURCE: tikking noise coming from engine
Yes, you're right, those could be the cause. Also, possible it's a collapsed hydraulic valve lifter, if your car has hydraulic operated (from engine oil) valve lifters. At any rate, it sounds like something loose in the valve train-valve lifter with push rod engines; or cam followers {rocker arms) with overhead cam engines that push on the top of valve stems .
Check a repair manual to see if your engine has valves that can be and need adjusting. Engines with valve lifters do not require periodic adjustment for proper valve clearance. Engines with rocker arms do require checking the valve clearance every couple of years or so.
Posted on Apr 10, 2012
  • 6468 Answers
SOURCE: 2008 toyota sienna noise from passanger side rear side when breaking or start to going
i would remove the wheel and inspect the brakes a pad might have seperated from the backing
Posted on Jun 30, 2012
Magnavox model 2006. When turned on, why does it make tik tik sound and turn off?
There could be internal arcing causing the tik tik sound. The power supply may have failed.
Sep 16, 2015 | Televison & Video
I am continuously getting tak tak noise while driving on 10-40kmh speed from front end left wheel. the mechanic said, its the problem of brake caliper. i have recently repaired the front axle and not done...
You don't state what vehicle it is. If it is a front wheel drive, check the CV joint, although this would be more prone to making a noise whilst in a turn.
Jan 27, 2011 | Suzuki Aerio Cars & Trucks
Streeing Noise
Sep 28, 2009 | 2006 Mitsubishi Lancer
Whirlpool door alarm
Is just a little switch on inside of the door hinge covers if you short it out the alarms will never go off again.
Jun 28, 2009 | Whirlpool ARC4030 Stainless Steel Top...
It wont start , has a click-click -click sound when you try to start it
Try trouble shooting by using another battery to start the vehicle. If it does not start, then the starter must have gone bad.
Rate this please.
Apr 25, 2009 | 1999 Dodge Caravan
Refrigerator continuously cycles
This is a generic problem with Whirpool refrigerators.The start relay for the compresor(located on the side of the compresor under the black plastic cover) is probably bad ,replace it(about $ 20) with a new one(write down where the wires go) that should solve the problem if not the compresor is bad.
Apr 15, 2009 | Whirlpool Refrigerators
Power not wrokign properly
check secondry side of sm txr for shorting
Jan 10, 2009 | SAMTRON 55V 15" CRT Monitor
Refrigerators Logo
16 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
