Question about Alesis Q25 25Key Keyboard Midi Controller
My Alesis master effects Q20 will no longer power up?
How to do a factory reset on a alesis s r 16 drummer
Power up while holding play-erase. BUT...when performing a re-initialization, this will erase all existing patterns, songs, and drum assignments. This will not erase the factory preset patterns or kits.
http://community.alesis.com/alesis/topics/sr-16-factory-default-reset-question
Sep 27, 2017 | Alesis Music
How do I connect Aleis gt with alesis q2
Those units are both made to go in the effects loop of an amplifier, you would want to hook your effects send to the input of one unit, then the output of that to the input of the second unit, and the final output into the effects return of your amplifier
Feb 24, 2015 | Alesis Music
How do I reinstall preset patterns
According to the Alesis SR16 Frequently Asked Question section: Power On while holding down Erase and Play. http://alesis.com/sr16
Feb 15, 2015 | Alesis Sr 16 Stereo Drum Machine
Connected alesis sr16 with alesis 110v power supply.to 240v mains...........briefly powered up and then nothing. Have I "fried" the adapter or the sr16?
Look carefully at the adaptor and see if it takes any voltage besides 110 (it will say in very tiny print, you will need a magnifying glass). if it does NOT say 220V or 240V then you friend the adaptor. Get another adaptor - most are "dual" voltage meaning they run in the U.S. or overseas.
Also check for "polarity" (which part of your plug is + or - ).
Jan 24, 2013 | Alesis Sr 16 Stereo Drum Machine
What do you hook up first, mixer or power amp oreffects in a rack system?
Effects plug into mixer, mixer plugs into power amp. Others may want the mixer and the effects plugged into the power amp for the most available inputs. (when multiple inputs are available.)
Effects and mixer are a line level output and the mixer can be considered a line level input as well. A mic mixer has gain amplifiers for the inputs that are below line level such as unamplied microphones. It is possible to parse to absurdity, but the gist of it is above assuming you do not want to apply the same effects to everything all at once.
Feb 06, 2012 | Soundcraft Efx12 12-channel Mixer With...
My quadraverb has no effects information on the screen, but all the effects work well .can someone tell me why thanks jon.
there may be maybe 2 a causes like it has a cut board or just the 7 segment fails!and need to replace a new one 7 segment
Jul 16, 2011 | Alesis Multimix 8 USB Powered With Effects...
Right speaker sounds louder than left thanx
Besides checking balance, cables and length of cables can cause that. If cable is weak, or if one side is longer than the other, you'll get that effect
Feb 28, 2011 | Alesis M1 Active 320 USB Speakers
Sound output is heavily distorted.
Check following things:
1. The master volume control on the SR16 is at least half way up. Turn down the amp as needed. Running very low output of the SR16 and high amp gain is sure to get distortion.
2. Check power adapter is the original and is producing correct voltage.
3. Check that audio cable is high quality instrument cable and not consumer or speaker cable.
May 05, 2010 | Alesis Sr 16 Stereo Drum Machine
The sr-16 powers up briefly then shuts off, I'm using a new AC adaptor ,music store repairman say it's unrepairable ,it's only 2 years old,what gives?
There has to be a component inside that is faulty. That causes the power supply to quit. If the repairman said it is not able to be repaired it means that the part can't be replaced due to unavailability or the cost. You could try taking it to another repairman at a music store that sells Alesis products if you aren't satisfied with his his answer. SR-16 s are pretty reliable and it takes a lot to damage them to the point where they can't be repaired. If you can't get it repaired locally and you think it can be repaired contact Alesis at http://www.alesis.com/content1024 to find out the closest place to ship it to and get it repaired.
Jul 09, 2009 | Alesis Sr 16 Stereo Drum Machine
Alesis Q25 25Key Keyboard Midi Controller Logo
15 people viewed this question
Top Alesis Music Experts
drivealot
Lawrence Oravetz
Robert Graf
Are you an Alesis Music Expert? Answer questions, earn points and help others
