Question about Intimus 250 CC Shredder
Bin sensor light on - Intimus 250 CC Shredder
Bin full light
The sensor build limestone residue during operation and needs to be cleaned off. The bin sensors are typically located on either side of the freeze platens and can be removed to clean. Turn machine off and unplug. Reach in past the water trough and freeze platen and you will see the transmiter and receiver plugged into the side walls. Gentlely work sensor loose and work sensor wiring out hole until you can get to sensors. Clean the two sensor with a clean cloth and with vinegar until sensers are clean. Reinstall, and plug back in and start unit. Bin sensor light should be out and should start.
Aug 24, 2013 | Scotsman Refrigerators
MV450 Scotsman Ice machine
1. bin full when bin is empty means that the bin control sensor is dirty or need to be replaced. But since your having problems with water over flowing also i would bet that your machine needs a good cleaning. is you water full light on or off? if off and water sump try is full then you need to pull water sensor out and clean or replace it. if water sensor light is on then you need to replace water inlet valve.
Jun 26, 2013 | Kitchen Appliances - Others
Where are the bin full sensors located for cme256ws-1c full light on will not make ice
The bin full sensors are located behind the water sump tray. Pull the front cover off remove the white plastic guard. Remove the ice deflector grate that is in the water sump tray. Now look where the ice falls down into the bin to the right and left side there is where the bin sensors are you have to pull them sideways you can also open the control panel and look where the bin sensor wire runs and follow it. pull the bin sensors and clean the eyes or replace them.
Jan 03, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
The "Bin Full" indicator light
There is a sensor in the bin area of the machine that is faulty. If you have cleaned the bin area completely and still have that problem then the sensor is bad and will have to be replaced. Look on the manufacturer website for the replacement part.
Jul 11, 2011 | Quartet gbc 4220S Shredder
Re attach output bin error swaped known
Look for the sensor that is tripped when the output bin is attached. Trace the wiring back to origination. Either sensor is bad or wiring is bad.
Nov 24, 2009 | HP LaserJet 4345mfp All-In-One Printer
The empty basket light stays on all the time
Try cleaning the bin full sensors. located on both sides of your machine, inside the bin,under the cutter head. If that does not solve problem, you need to replace bin full sensors.
May 04, 2009 | Fellowes Powershred 320 Shredder
Scotsman cme506
i service scotmen cme506 blink 2 times in the water iclean bin sensors check water lebels install new inlet valve and due same
Apr 14, 2009 | Scotsman Cooled Modular Contour Cuber...
The "bin full" keeps on coming on
first off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
razors
Jan 20, 2009 | Fellowes Manufacturing Powershred C-220...
Intimus 250 CC Shredder Logo
23 people viewed this question
Top Intimus Office Equipment & Supplies Experts
Lonnie Arks
Lawrence Oravetz
ray gallant
Are you an Intimus Office Equipment and Supply Expert? Answer questions, earn points and help others
