Question about Fisher and Paykel Fisher & Paykel Washer
F&P GW709 top loader filling water intervally
  • Jason Bongos Aug 04, 2013
    Hi and thank you for taking the time to help. Now when I turn it on it likes to beep until I switch it of at the wall. The lights that come up are the 2nd,3rd,5th and the 8th.
  • Fisher and P... Expert
  • 554 Answers
Error Code 105
105. (01101001) Phase 2 to 5 - Comms. Error Time-out
These faults are reported when the Display module detects an error in the communications
between the Display module and the Motor Controller.
NB. If the product is an IW, check that the motor controller is not 426520. If it is replace with a
compatible part. This is incompatible and will give a fault code 105 at the start of agitate. Not
before! If it is a 426520 replace motor controller with a compatible part.
Primary Source - Display module
Action - Replace Display module.
Secondary Source - Motor Controller
Action - Replace Motor Controller
Tertiary Source - Rotor Position Sensor (Phase 5 Only)
Action - Replace Rotor Position Sensor. If the new Rotor Position Sensor corrects the fault refit
the original display module and motor controller.
Posted on Dec 13, 2013
My Fisher & Paykel GW709 Top Loader has stopped working. It stopped mid cycle. I turned it off and back on but it won't even light up now. Ii makes a short buzzing noise when you hit the power button but...
you need to check your pump and motor for shorts to earth, or low resistance readings across windings. the motor controller board will need replacing also most likely.
Sep 03, 2013 | Fisher and Paykel GWL11 Top Load Washer
Hi my GW709 7.5 smartdrive excellence won't fill with water and won't agitate if I manually fill it , help me please
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Feb 12, 2013 | Washing Machines
My samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Nov 04, 2012 | Washing Machines
My top loader whirlpool (3yrs old) appears to be causing stains: after careful monitoring it appears the fabric softener container conitunes to leak/drip/run down the central column - so staining sheets,...
You can try a few differnt things, staining is usually caused by not hot enough water to disolve or hard water issues. A Washer cleaning use one gallon white vingar fill up washer with hot HOT water let sit over night than run washer next day on HOT hot. Second try washing in warm to hot water dluting softner more breaks down better. Also dluting the softner more in the cup will help washing in cold causes alot of these issues, Make sure water heater turned up hot enough, make sure washer has hot water fill?
Aug 23, 2011 | Whirlpool Washing Machines
MY GW709 STOPS DURING FILLING UP WITH WATER AND IF YOU PRESS THE SPIN BUTTON IT WILL SPIN AND STOP FOLLOWED BY AN ALARM
Hi Benjimin,just read your posting.Now when the machine stops and beeps it will light up a series of lights.These lights will be in a row of 8 lights.Starting from left to right which ones are lit?Is it the 2nd and 4th or the 3rd and 7th ----etc----?Please reply with additional information and I am sure I can help you.
Aug 22, 2010 | Fisher and Paykel GWL11 Top Load Washer
F&P washing machine:GW709 doesn't cut out when filling
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
Apr 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
Hot water will not enter machine. Screen filter is clean. Cold is OK.
There's no hot water Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine isn't working the way it used to--or should--try these tests: Is the hot water turned on? If not, turn it on. Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct. Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
Feb 04, 2010 | GE WDSR2080D Top Load Washer
Top loader washing machine does not fill up
very simple, your drain hose is below 4 ft, your drain hose should go in the hole between the hot and cold water, if you dont see a hole then it is covered, you need to knock out the hole...
Nov 10, 2009 | Washing Machines
Kenmore Top Loader
try different temp settings be sure screens in inlet valve end of hoses are clean and taps on all the way if you gave water to washer and still none coming in suspect bad fill valve
Sep 03, 2008 | Kenmore 24032\24036 Top Load Washer
Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Dec 31, 2007 | Kenmore 24622 Top Load Washer
Washing Machines Logo
112 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
