Question about Tablets & eReaders
Restart for onda v811 - button reset
How do I convert the Chinese operating systems on my Onda tablet back to English
You should be able to go to your settings and change the language to English. If not you may have to do a reset and set the tablet up again and if you do then the addition applications and data you put in maybe lost. Not sure with this tablet. I was unable to tell if you could get to your settings but I hope so. Good Luck.
Dec 26, 2015 | AMERICAN Tablets & eReaders
Where is the reset button on the kindle fire?
According to eHow.com: " E-Reader Soft Reset
  • 1 Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
  • 2 Choose "Menu" again from within the Settings menu. This displays a different menu than before.
  • Sponsored Links
  • 3 Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
  • 1 Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
  • 2 Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
  • 3 Wait while your Kindle restarts.
E-Reader Factory Reset
  • 1 Press your Kindle's Menu button. Select "Settings" from the menu.
  • 2 Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
  • 3 Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
  • 1 Hold the Power button down for three to five seconds. A Shutdown window appears.
  • 2 Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
  • 3 Press the Power button to turn the device on again.
Fire Hard Reset
  • 1 Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
  • 2 Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
  • 3 Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
  • 1 Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
  • 2 Tap the "Settings" option and select "Device."
  • 3 Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
Read more : http://www.ehow.com/how_6122863_reset-kindle.html
May 10, 2015 | Tablets & eReaders
How do I reset my first generation Kindle Fire and where is the reset button
Restarting Kindle Fire may resolve intermittent issues like a frozen screen, battery issues or trouble downloading content to your Kindle Fire.
To restart your Kindle Fire, press and hold the power button for 40 seconds and then release. After the device has completely turned off, press the power button to restart your Kindle Fire.
If your Kindle Fire is still unresponsive, try charging your Kindle Fire before trying to restart the device again.
Make sure you have the latest software version available installed on your Kindle Fire. The latest version is available at www.amazon.com/kindlesoftwareupdates
Mar 01, 2015 | Tablets & eReaders
The touch screen in my Ipad stopped working. It works to unlock or to shut a screen but that's all.
Try restarting it: hold power button down until "slide to power off", power off for 10 seconds, press power to restart.
if that doesn't fix it, reset your iPad: hold BOTH power button and Home button until device resets and apple logo appears.
Feb 14, 2015 | Apple iPad Mini
My tablet won't connect to the wifi, I tried to reset it so it can start from 0 but it won't even reset. What can I do?
To perform a factory reset, you will need to do the following: -turn of the tablet -press the following and hold: power button reset hole -hold until you see android logo screen -poke the reset hole to navigate to `wipe data` or `factory reset` -select using the power button -select delete all user data -restart the device -choose restart/reboot after reset This procedure will delete all apps and data on your table
Jun 30, 2014 | Tablets & eReaders
Coby mid8065
1. Turnn completly off the tablet.
2. With the tablet turned off, holding the return button while turning on the tablet-pressing power button. Keep holding the return button until you see the Hard Factory reset screen.
3. Confirm the hard reset procedure. Once done, simply wait until process has finished-the tablet will restart. This process can take up to 30 minutes, so it's very important that the battery of the tablet is completly charged before attempting the hard reset. If you can connect it to the charger while resetting, even better.
Regards! If that helped, don't forget to accept my answer!
May 31, 2014 | Coby MID8065-8 - Kyros MID8065 8 8 GB...
Hey I have a Vi30W onda tablet but when I try to turn it on it stuck with the android logo and I dont know how to actually turn it on.
it sounds like you're at the emergency recovery screen, volume down to see the first menu, select option 1 reboot device, do not select anything else.
Dec 27, 2013 | Onda Vi30W 8 Inch Capacitive Screen...
Onda v711
You need to perform a hard reset on your Onda V711. Here`s how: You can perform a hard reset by booting into a special recovery mode. First, ensure your device is fully shut down. When the tablet is turned off, keep home button pressed.
Now turn on tablet while still holding the home button.
When white android figure appears, release both buttons.
You will get into recovery mode, you can select "restore factory settings" there.
If that fails, try flashing new firmware.
May 03, 2013 | Tablets & eReaders
Tablets & eReaders Logo
203 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
