Question about Neff Bandit Watch
My neff bandit needs battery's and I don't know how to change them.
Changed the battery, hands move slowly but doesn't keep time...help
There is likely something wrong with the gears and mechanisms inside.... you can contact the manufacturer and ask if others have had a similar problem, and see if they might have a solution. Other than that, you may just have to get a new watch.
Feb 07, 2016 | Neff Daily Sucker Blue & Black Analog...
How do i turn off alarm on my neff flava watch ?
Here is a YT video that is helpful for this question:
Neff Flava Watch SKU 7879816
answers can be found here:
How to change time on neff flava watch
Apr 13, 2015 | Neff Flava Green
Neff daily watch
Does it come with a battery in it? I've had watches where there was a little clear plastic tab you had to pull to allow the battery to make contact and the watch to run. If not, then all I can suggest is to but another brand of watch. Here's their web site link. At the bottom of the page is the contact link...good luck.
Front Page
Mar 29, 2014 | Neff Daily Watch - cyan/pink/black
I bought a Neff daily black analog watch at Zumiez about a month ago as a present for a friend. the problem is that the minute hand and hour hand do not move... you can move them to set the time but once...
I would take it into a jeweler and they will put a new battery in it for $4. If that fixes it all well and good, if not it cost you 4 bucks to prove it needs to go back under warranty.
Feb 06, 2014 | Neff Daily Sucker Blue & Black Analog...
Date is wrong on neff watch
Keep pressing mode until you get to where you get to edit the time and press the "light" button until there's a big number and that's the month and keep pressing the light button and you can edit the date and what day it is
Dec 16, 2012 | Neff Flava Watch Watches
I dont know how to change it
Hi Mateo,
I suppose you don't know how to open the backside of your watch, to replace the battery.
If that is so, check the back side of your watch. At the edge of the centre cover, or just under it, there is at 1 place a little notch of a view millimeters. Juse a small screw driver or tweezers for instance to lift it up. If you don't succeed, the cover might be tight and sticky. So you need to put the back side of your watch on a hot and wet cloth. That might help to loosen the sticky edges.
Good luck ;)
Andre
Oct 20, 2012 | Watches
Changing battery on TE4027 watch
Pl don't try yourself better visit a well experienced watch maker to replace it otherwise you will finish with worse
Jun 23, 2012 | Ted Baker TE4027 Watch
I have citizen eco-drive skyhawk not under warranty. Two weeks ago everything turned off. Nothing works. Do i change battery is there replaceable battery in these watches? I know when i bought it they...
The watch has a "battery" and claims that it does not need to be replaced but perhaps it needs re-charging. If you go to their web site (click on the link below), there is a full explanation of re-charging requirements :-
http://www.citizenwatch.com/COA/English/rechargeguide.asp
May 23, 2011 | Citizen Eco Drive Skyhawk with Atomic Time...
Neff Bandit Watch Logo
Top Neff Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Neff Watch Expert? Answer questions, earn points and help others
