Question about Audio Technica AT-PL120 Turntable
Anti skate anti-skating doesn't work properly
What is better figer skating or hokey. and why
That depends on an individual themselves. There is no answer to your question which can speak for everyone. So it's is up to you as an individual to come up with reasons why you would pick hockey over figure skating. Here are some arguments, figure skating is artistic(art), peaceful where as hockey is a rough sport requires strong and muscular body and is action. Here is an article take time to read it maybe you
Battle of the Blades Hockey VS Figure Skating Hockey vs Figure Skating Edit
Nov 22, 2016 | Sport & Outdoor - Others
What is ice skate? And where can I get the ice skates for girls?
ice skating is like roller skating only on ice
ice skates are available from most sports shops
Oct 14, 2016 | Sport & Outdoor - Others
Anti skating
Skating is when the stylus slides across the record's surface and doesn't stay in the grooves. This can happen when the stylus is too worn and so any control to correct it called "Anti Skating" won't work. Getting the pressure right to the stylus is the first thing to do. Once this is set up if an odd record then skips a few grooves on a good condition record, you can adjust the Anti skate control to prevent it. Adjustment it is like setting the stylus pressure, a question of trial and error.
Jan 16, 2014 | JVC Audio Players & Recorders
How can I maintain my figure skating blades and boots?
Keeping your figure skating boots and figure skating blades dry is the key to their longevity. Figure skating blades should never be stored in plastic blade guards!! Always wipe off any moisture from figure skating boots and blades. You can use teri-cloth blade covers, Zookers, or Blade Blankies to store figure skating blades. It's typically a good idea to occasionally take your figure skates out of your skating bag to let them "air out". Also, never leave figures skates in your car during warm weather seasons. Most figure skates are heat moldable and leaving them in the car can misshape and ruin your figure skates.
Answer from: http://figureskates.discountskatewear.com/t-Faq-figure.aspx
Jan 17, 2013 | Sport & Outdoor - Others
Specs for Technic Sl1210M5G Turntable
Anti skate should be set the same as the weight, i.e 3 gram of weight = 3 on the anti skate.
http://stores.ebay.co.uk/methleykev
May 19, 2010 | Technics SL-1210 Turntable
Stylus skates across record; doesn't engage grooves
Increase the weight of the arm, check if it has anti-skate control.
Dec 30, 2009 | Audio Players & Recorders
Sears Tape deck/Turn table skipping!
Hi the pennies will mess up the stylus. There should be an anti skate setting at the back of the turn table, a round adjustable bit with numbers, increase the anti skate and then use the balance weigth (weight right at the back of the arm that turns to get the weight right. Set the anti skate with the tone arm light, then increase the weight a bit. Hope that helps
Jun 14, 2009 | Technics SL-1210 Turntable
Marantz TT221 turntable anti-skating problem
Hi, sounds more like tje stylus tip is gone and therefore the needle isn't holding to the grooves rather than a tracking weight or anti skate problem. Styluscity@gmail.com
Mar 27, 2008 | Marantz Reference TT-15S1 Turntable
Audio Technica AT-PL120 Turntable Logo
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Paul Bade
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
