Question about Kitchen Ranges
I want to change our door seal on a Dovre 250 multi fuel stove but I cannot get the door off how do I do it
  • 1462 Answers
SOURCE: i NEED TO CHANGE THE
turn off at mains
undo clamp that holds seal to cabinet and peel seal away from cabinet.
take worktop off
undo clamp that holds seal to tub and seal will then come away
on new seal, lubricate the slot in the seal that goes onto lip of tub with washing up fluid
starting at top, insert slot in seal onto lip of tub and work you way round in both directions till seal is entirely on tub.
replace clamp
fit seal to cabinet (this is easy) and refit outer clamp.
test on rinse cycle as water level is higher. water will foam till washing up fluid is washed away
Posted on Sep 09, 2008
  • 34 Answers
SOURCE: Have a Dovre 750 gas direct vent stove. How much
Dovre is actually an old gas stove manufactured by what is now Hearth and Home Technologies. This is a discontinued model. visit www.quadrafire.com for technical support. If they won't or can't help you let me know I think I have the older tech manuals somewhere.
Posted on Apr 18, 2009
  • 415 Answers
SOURCE: Hi i am searching for a manual for a Dovre 500
Here is the Installation & Operators Manual. :-)
Posted on May 01, 2010
  • 53 Answers
SOURCE: i want to place my new multi fuel (wood/coal)
yes as long as you use a class b vent pipe thats a double wall pipe and you would okay
Posted on May 19, 2010
news775
  • 699 Answers
SOURCE: I need a slow speed
If you want to control the fan speed on the log burner you need a variable power control that is suitable for inductive loads as dimmer switches are for resistive loads.
Your best bet is to goto a shop that sells log burners and ask for a fan speed controller.
Please dont forget to vote if you liked my answer
thanks
Posted on Feb 11, 2011
Stoves 720ef bottom door not touching seal at top
Try adjusting the hinges also check magnetic seals on door itself as well.
Feb 22, 2013 | Stoves 720EF Electric Double Oven
Is the gas stove Dovre model DV450, by heatilator, serial # GA384694 a B -Vent or Direct Vent?
Janny, generally with Heatilator gas fireplaces, the letters in the Model Numbers indicate whether it's a Direct Vent or a B-Vent. In your case, it's a Direct Vent. Had it been a B-Vent the Model Number would be BV450.
Hope this answered your question. Please be knid enough to rate my reply to you. Thanks.
Mar 24, 2011 | Heating & Cooling
I need a slow speed motor resistor for a dovre 2200 log burner stove.
thanks
Feb 11, 2011 | Office Equipment & Supplies
How far away from the wall should a dovre astro 4 be? My fire has been on for an hour and has started to melt the paint on the wall behind it has now started to fall off
according to the manual it should be 200mm away (rear) from a wall containing combustable material and 500mm either side
http://www.dovre.co.uk/pdf/Astroline%203_4%20MF.pdf
May 19, 2010 | Kitchen Ranges
I am trying to shut down my stove at night to keep it going. (not burning out) How do I do this?
air is still getting in from somewhere when you shut all the dampers and doors. door seals if fitted may not be sealing. if you have only tryed wood as a fuel try coal to see if it stays in. but air feeding the fire is the problem
Feb 11, 2010 | Kitchen Ranges
Have a Dovre 750 gas direct vent stove. How much pipe do i need before i elbow through the wall?
Feb 26, 2009 | Heating & Cooling
Kitchen Ranges Logo
62 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
