Question about Panasonic PT-60LC14 60" Rear Projection HDTV
Lamp replacement How do I replace the lamp. No instructions came with the new lamp and none are in the manual. I apparently also need to reset the lamp life timer.
  • alfelix Nov 22, 2007
    how hard is to replace tube
  • cafmiller23 Dec 02, 2008
    I also have the same issue - need to replace the lamp as well as reset the timer. Anyone have instructions for the consumate do-it-yourselfer?
    Thanks
Go to this PDF for instructions
www.911phone.net/Panasonic_TY-LA1000_Instruction_Manual%5B2%5D.pdf
Posted on Nov 06, 2007
3 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: lamp replacement
The file is too large to post here but if you post your email address, I can send you the step by step instructions to replace the lamp and reset the lamp hour counter.
Posted on Mar 03, 2008
  • 1894 Answers
are you experienced in electronics first?
with out proper knowledge of electronics it is too risky to do it by yourself.
Posted on Jun 27, 2008
Message on screen says lamp needs to be replaced then timer reset. Need lamp and instructions to reset timer
The lamp time reset will be or should be in the owner manual---Google the model number with keywords "lamp install" with the model number and the "manual" with the model number---Google can be a great help.
Nov 01, 2012 | JVC Lamp W/ Housing For Hd-52g786 /...
Lamp replacement
Jun 27, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
I replaced the lamp and it still indicates that the lamp needs to be replaced
The lamp timer must be reset and so this will reset the processor to switch on the lamp.Please follow instruction on the manual, open main menu and proceed as directed.
Dec 17, 2011 | Sanyo PLV-Z4 Multimedia Projectors
How to reset lamp timer on pt 50L C-13
Their manual says:
After lamp replacement, you must reset the lamp
time. Refer to the instructions enclosed with the
lamp unit (Part No.: TY-LA2005).
lamp unit (Part No.: TY-LA2005)."
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC13
Aug 09, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I JUST REPLACE MY LAMP IN MY SONY KDS-55A2000 HOW DO I RESET THE LAMP HOURS..TV IS STILL READING PROJECTION LAMP NEARING LIFE END
you need to go into the TV's menu and select replace projection lamp menu and follow the on screen instructions to verify and reset the lamp timer, (its in your instruction manual , in detail) , i am awaiting a new phillips bulb for mine, as i always use the original enclosure, no need for extra plastic, and its easy to complete the swap, and reset hours via TV menu
Aug 03, 2010 | Sony KDS55A2000 55" HDTV
Lamp is not coming on. It was replaced recently Benq 8720
Check in your instruction Manual about pressing a button sequence while starting up. Some projectors do not actually know when you have changed the lamp, so you have to reset the lamp timer by pressing a button sequence. Often a genuine replacement lamp will have an instruction set which comes with the new lamp ( If you still have it !! :) You may have replaced the lamp but not reset the counter and it has shutdown because the counter has reached a critical umber of hours.
Jan 02, 2010 | BenQ Office Equipment & Supplies
Panasonic LCD Lamp Replacement
Here is the manual for your set, the instructions for replacing the lamp are on pages 66-67.
You can download the manual here.
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-61LCX65
To reset the lamp timer
For the full instructions and how to reset the lamp timer go to the following site
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Aug 21, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Projection lamp nearing end of life replace lamp still coming on
Along with the instructions for the lamp installation, you should have revceived instructions on how to reset the lamp counter. If not, this operation is listed in the owner's manual. If you can not locate that manual, please confirm your model number and I will post the instructions. Since the counter has not been reset, the TV will continue to show the "error" message.
Dan
Mar 09, 2009 | Sony KDF46E2000 46" Projection HDTV
Infocus Lp240 Projector Will not power on NEW BULB. Red light Blinks on and off.
The owner's manual should have a troubleshooting chart that will indicate what the blinking lights mean. If the new bulb did not clear it, the problem may be the ballast (part that starts the bulb). Also, when you replaced the lamp, you should also reset the lamp timer. Some units will continue to indicate a lamp needing replacement until the counter is reset. The procedure for that should also be in the manual.
Keep us posted.
Dan
Dec 18, 2008 | InFocus LP290 1100 Lumen XGA LCD Projector...
Lamp replacement
Mar 01, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-60LC14 60" Rear Projection HDTV Logo
1,177 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
