Wharfedale DMP82 mini hi-fi unit. It's stuck in standby. When the standby switch is pressed, the display lights up then goes back to standby. LCD display is on as the 5v line is still present. The 2 x 14v lines are at 4v and rise momentarily as does the 12v line. The standby line is 0v then rises to 2.5v when the switch is pressed. Not an easy unit to take apart and I've only managed to get the back (PSU) off. Any ideas?
SOURCE: LCD TV - Vertical Blue line
use menu and h/v then change then move to higher level and it will take it away.
Posted on Aug 24, 2008
SOURCE: Wharfedale TV power problems
got a 32 inch wharfedale tv from argos also and it seems to boot up and then shut down and just loops, if i keep unplugging it i can sometimes get it on but with a high pitch wailing, only 15 months old, gutted!
Posted on Oct 07, 2008
SOURCE: Power issue with Olevia LT23
this is bull do...The same thing happens with my TV I Have the Olevia 23" and the power will not turn on.
$700 shot, who cares about the rebate when it works on a short while...
Posted on Nov 24, 2008
SOURCE: Power on problem for My Syntax Olevia LCD TV 23"
I have a 24" Olevia LCD TV. Same symptoms (Stdby LED is on, press power and it flashes off, then back on). The USB cable to the Service Port also worked. But being of sound technical mind, I figured this means that the PC is supplying the +5v to the circuit. What I did was disassebled the TV, carefully disconnected all the cables, and opened it up to reveal the circuitry. I looked over the circuit and noticed the 1000uf/16v capacitor at position CS21 was failed and bulging. I removed the cap, tested it and verified that it was indeed failed. I went to a local Radio Shack and picked up a 1000uf/35v electrolytic, after all, the value is what mainly matters as long as it's not lower voltage than the original. I replaced the new CS21 capacitor back in the circuit (it is polarity sensitive, so pay attention to what the original mounting position is). I reassembled the TV and Viola! Works! No need for the USB cable to the Service Port!
I hope this helps someone!
-Matt
Posted on May 18, 2009
SOURCE: Sony BRAVIA KDL-46XBR 46 in. HDTV LCD
I hope this helps
It seems Sony is extending the warranty on your TV
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank and Good Luck!
Posted on Feb 04, 2010
Where can I get a Amplifier Warfedale S-991 or spare transformer for this unit
Hi Dave. One just finished on the bay. http://www.ebay.co.uk/itm/Wharfedale-S-991-Amplifier-mini-H-Fi-integrated-amp-/230791689518 They may still have it ?
Jan 05, 2015 | Audio Players & Recorders
Sky box green light on permanent
Sounds as if the software is corrupt. Try a forced software update...
1) Switch the digibox off at the mains power, so no lights are displayed on the unit
2) Press and hold the BACK UP button on the digibox (not the remote control)
3) Whilst holding, switch the digibox back on at the mains power so the red standby light is displayed
4) Wait approximate. 10-20 seconds for the remaining 3 lights to display, at which point you can release the BACK UP button
5) Allow the digibox to download the latest software, which can take 10 minutes before returning to standby
6) Leave 60 seconds then power up as usual
A software update/refresh will leave your recordings intact. You won't lose anything.
If this doesn't solve your problem, then the next step is more drastic. It's a Full System Reset and Planner Rebuild. Be advised though: Your recordings are at risk!
1) Switch your digibox on
2) In sequence, press on your remote 'SERVICES > 4 > 0 > 1 > SELECT' (this will access the hidden menu)
3) Select the relevant option (usually the bottom two) and follow the on-screen prompts (note that it's likely your digibox will reboot between processes)
Applies to Sky+HD Digiboxes only, running latest EPG
1) Press Services on your remote control. 'Options' in the Top Menu will be highlighted in orange.
2) Press the Right arrow once to highlight 'Settings' in the Top Menu.
3) Now press the Down arrow once to highlight the 'settings' tab in the Middle Menu.
4) Press 0, 0,1, Select on your remote in quick succession. The 'Setup' tab will then be highlighted within a hidden menu.
5) Select the relevant option and follow the on-screen prompts (note that its likely your digibox will reboot between processes)
Sky Digibox Planner Rebuild / Full System Reset (if stuck in standby)
Applies to Sky+ and Sky+HD Digiboxes only
Same as above, but applies if your digibox is stuck in standby and you cannot get to the hidden menu:
2) Press and hold the 'right and left arrow' buttons on the digibox (not the remote control)
4) Wait approximate. 30 seconds for the blue Sky+ ring of lights to display, at which point you can release the 'right and left arrow' buttons
5) Press 'SELECT' on the digibox (not the remote control)
6) Now the system will format the hard drive, the blue Sky+ ring of lights should spin backwards
7) Allow the system to format, which can take 10 minutes before returning to standby
8) Try to power up!
Sep 02, 2014 | Televison & Video
Not switching on!
A short has transpired before the fuse. Now in protect mode. See a tech.
Mar 22, 2014 | Teac AG-980 4 Channels Receiver
Wharfedale ipod & subwoofer
Your hi-fi is not part of a hard drive or a shuttle computer. If you have a problem with your Hi-Fi, it would be best to tell us the make and model and ask in the Hi-Fi or stereo section.
Jul 12, 2013 | Shuttle MediaDock IS73/320 LVD...
Vivid mini hi fi wont turn on
when you plug it in it goes into stand by mode automatically, the LCD display will be lit and you can set the time but nothing else will function. you have to hit the on/standby button to turn it on.
Feb 04, 2012 | Audio Players & Recorders
Sony hcd-gx470 manual
My Sony Mini MHC-GX470 have been working until a power outage yesterday and now it will start coming on the goes back to standby mode. I can hear it going through the system, starts the radio and immediately goes to STANDBY.
I need HELP!!!!!!!!!!!!!!!!!!!!!!!!
Jan 07, 2012 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
HP monitor w1907 lcd switches off to standby.
your hp monitor has an electronic component problem inside, probably some busted capacitors or ccfl lamps that failed to light...best is to bring the unit to a qualified LCD repair center near you..
May 09, 2010 | HP w1907 LCD Monitor
When I turn on the camera, nothing happens and the screen/view finder is blank. i checked the standby switch its off. when i press record it will record but on the tape it is just a black screen? any ideas...
i know exactly whats wrong! the same thing happend to me.
1. turn off the gl1 2.look at the record button with the lock and standby switch 3.flip the switch all the way to standby because it might be stuck in the middle 4. turn on your camera
Dec 03, 2009 | Canon GL1 Mini DV Digital Camcorder
My Philips mini hi-fi unit was on eco-power, and when i went to switch it on, the red light went out but the unit didn't come on. The unit now doesn't work and it's nothing to do with the plug or the...
if it has been in standby for years the power supply has died .dont bother to much to fix £150 plus ditch it commo fault with all units left in standby they die in the end regards kirk
Dec 09, 2008 | Philips Audio Players & Recorders
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
