Question about Panasonic SC-HT670 System
Init please wait
I think i have created an alignment problem with the trays of the unit. i cannot play audio or dvd's. the display says init please wait and wait stays on the display.
  • 2 more comments
  • mjeado Dec 16, 2007
    I have the same problem but says init wait close on the SC-PT1050
  • rochester08 Aug 15, 2008
    The bottom tray slides in slightly when the unit is powered up, there's a grinding sound, and then it slides out slightly and the unit says "please wait" and won't do anything. I pulled the tray unit out. This happened once before and they said there was a gear that was broken. This time the repair shop refuses to even look at it. Everything looks fine, but I can't figure out how to get at the actual mechanisms.
  • nick4543 Dec 21, 2008
    but we have no idea how to realign them it keeps binding up and we cant find a release for the trays so the gears can do what they have to do and be set back to normal
  • dewindt-empa Mar 25, 2009
    same one but with no answers
  • 4 Answers
I've just spent the last 3 nights trying to fix that same issue with my sa-ht670 player. I ended up pulling out the dvd tray assembly, and making sure there wasn't anything broken inside or obstructing other pieces. Come to find out, my 1 year old had pulled on one of the trays and it pulled the tray off it's tracks. After that, it would just go to "init please wait" forever. I pulled the side track cover off and aligned the tracks manually. Everything had to be absolutely perfect or else you'd get nothing. After the fact, I realized that there were two holes in the bottom of the player that you can take a spare small gear (which is attached to the plastic cover on top of the dvd tray assembly) and stick it in there and manually adjust the tray positions to make sure everything is aligned properly. After messing with it three days, it ended up being quite simple to fix. Everything works like a charm now. If you need details, feel free to email me.
[email protected]
Posted on Apr 14, 2008
  • alex_martine Jan 05, 2011
    Awesome, you saved me a few hundreds on a new HT system, I had it in my closet for almost 5 years but I didn't give up, great 2011 start, feels as I just got a new system.
    Awesome, thanks for the help !!!!
    New Friend:
Did it make a crunchy(something stuck) sound when it turned the player on?
Posted on Nov 26, 2011
SOURCE:
My system says INIT please wait and the cd/ dvd trays are out of line i tinkle a little with electronics and feel that if i knew a little more about this problem I can fix it myself,especially due to high...
  • First you to pull out the DVD tray assembly and check to make sure there is not anything that has broke inside there. Make sure nothing is blocking the trays from moving.
  • Now pull the side cover off. There is a spare gear on the top of the DVD tray assembly. You will take that and place it in the two holes at the bottom of the player. This will allow you to manually adjust the trays. If you don't have this gear you can align the tray manually but it has to be real perfect.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 26, 2011 | Panasonic SC-HT670 System
Not playing NTSC DVDs
I can see if there is an unlock code for your device
Apr 21, 2008 | Yamaha DVR-S150 DVD Player
20F510TD
eject the cd tray and use canned air to clean the inside of the cd/dvd unit, just use stick the nozzle near the opening and give it a through dusting. after that, run a cleaning disc through it a few times.
if that doesn't clear up the problem, the dvd player will need to be serviced, most likely either a lens replacement or re-alignment.
hope this helps,
trin
Nov 20, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
Error code FO6 onVCR SD200
Hello
It is due to busy and confused memory IC by so many unfamilier external commands. Just reset the device to its factory setting.
The ratings level returns to the factory preset. While the disc tray is open, press
[DRIVE SELECT] to select the DVD drive, then press and hold REC button and PLAY button on
the main unit at the same time for 5 or more seconds ("INIT" will appear on the unit's display).
Leave it for some time till initilisatin has beed done.
OK.
Jul 20, 2011 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Says wait, won't play dvd's at all
Yes you are right, this will happen only when tray mechanism is not working at that time lense will try to read but it will be still under wait condition,
to resolve your issue you need to replace entire tray with lense set to work properly.
Mar 29, 2009 | Panasonic SC-HT670 System
Panasonic SA-HT680 Home theater problem
Try these steps to reset the unit. I got these from the Panasonic Cust. Service # 1800-211-7262
1. Unplug the unit power.
2. Wait 2-3 mins before replugging the unit.
3. Turn it on.
4. If the display shows INIT / PLEASE WAIT, Press and HOLD the Tune Mode (STOP) button on the main unit. At the same time press #10 (Channel button) in the remote control. They have to be pressed & held simultaneously for atleast 5 seconds. Wait till the INIT / Please Wait display disappears.
5. Once the message disappears, RESTART the main unit by pressing the POWER button OFF / ON.
6. If it does not work, try several times. If it does not work, contact a local repair shop (call them to find out a repair shop near you). If the repair shop wont do it for you, call them back - thats what they told me.
Jan 19, 2008 | Panasonic SC-HT680 System
Jamed
I've just spent the last 3 nights trying to fix that same issue with my player. I ended up pulling out the dvd tray assembly, and making sure there wasn't anything broken inside or obstructing other pieces. Come to find out, my 1 year old had pulled on one of the trays and it pulled the tray off it's tracks. After that, it would just go to "init please wait" forever. I pulled the side track cover off and aligned the tracks manually. Everything had to be absolutely perfect or else you'd get nothing. After the fact, I realized that there were two holes in the bottom of the player that you can take a spare small gear (which is attached to the plastic cover on top of the dvd tray assembly) and stick it in there and manually adjust the tray positions to make sure everything is aligned properly. After messing with it three days, it ended up being quite simple to fix. Everything works like a charm now. If you need details, feel free to email me.
[email protected]
Nov 22, 2007 | Panasonic SC-HT670 System
Unit says Init Please Wait
[email protected]
Oct 31, 2007 | Panasonic SC-HT670 System
Panasonic SC-HT670
[email protected]
Sep 24, 2007 | Panasonic SC-HT670 System
LOCKED displays when attempting to eject disk from SA-HT670
i have a panasonic SA-HT720 and it displayed locked anytime i wanted to eject discs so i found out that dad27's solution was the best and holding down the stop and power buttons also locks the system as well as unlocking it. God richly bless u dad27 u really helped me out
Jul 27, 2007 | Panasonic SC-HT670 System
Panasonic SC-HT670 System Logo
2,513 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
