Question about Garden
Changing blades on TC910NSRD Caroni finish mower.
2 Suggested Answers
  • 8 Answers
SOURCE: WHEN I FINISH MOWING YARD I DISENGAGE MOWER BLADES
If this mower has a manual lever that has to be pushed up in order to engage the blades then check the tension pulley that connects to the lever cable on the top of the deck,it probably need to be lubricated or cleaned in order to move freely back to the normal position.
Posted on May 18, 2010
How to replace plastic blades on a challenge mower
Dave, Remove plug wire, raise mower, or tilt on it's side to access blade. Remove center bolt holding blade on, noting the position so as not to install new blade upside down. Install new blade correctly and tighten blade bolt tight. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change Lawn Mower Blade
Lawn Mower Repair How to Remove Lawn Mower Blades
What Direction Do Turn the Nut to Change Mower Blade
Jul 28, 2016 | Garden
Tip
Replacing Riding Lawnmower Blade Belts.
I discovered on a Craftman Riding 3 bladed mower that there is an easy way to replace the belt for the blade pulleys.
The mandrel cover of the Left side blade is the only part you need to remove to replace the belt. You can insert the belt under the right side mandrel cover and onto the clutch pulley before finishing on the left side of the mower.
The tensioner or idler pulleys will contract when you pull on the belt. When you get to the left blade pulley you can turn the pulley with one hand and guide the belt with the other hand. The belt will walk right up onto the pulley. Attach the cover and you're done.
I like my method because you can stay away from a hot engine and replace the belt without waiting for the motor to cool off. You are also not fighting the mower clutch or drivebelt with my method.
on Dec 16, 2010 | Garden
Why is my electric Black and Decker lawn mower still vibrating and loud after I replaced the blade insulator and fan?
disconnect all power and turn the mower on the side
turn the cutter blade /base by hand and watch the centre bolt or shaft
if it moves in a bit of a circle then it indicates that the motor shaft may be bent, causing the vibration at speed
Aug 03, 2015 | Electric Garden
How do i change the mower blades on my honda hru19d
Check this site for changing mower blades. Seems straight forward:
HOW TO CHANGE LAWN MOWER BLADES
Feb 11, 2015 | Honda Garden
Is there a shear bolt on the caroni tiller 5ft?
Yes all tillers and snow blowers that size need shear bolts in the tiller in the case it would get stones lodged between the tiller blades and the shield..or packed snow,ice or even stones in the auger ,..you may get away with using a soft steel bolt but sooner or later you will be replacing a broken gear box..even if yours does not have them get them..a $2 bolt or new gear box your choice.Just measure the bolt length and the shaft diameter not any shear bolt will due..the grooves on the bolt are meant to be the same size as the shaft diameter to insure shear at the shaft area that is under extreme pressure..Hope this helped..good luck.
Sep 29, 2014 | Garden
How do I change out the blades on a john deere 155C 48
Jack up the mower so you can see and reach the blades.
Loosen the bolts/nuts holding the old blades. Remove. Install the new blades. Tighten the bolts/nuts, finished.
Apr 22, 2012 | Garden
I have a Bolens riding mower. It worked fine yesterday, but when i went back out to finish yard it wouldn't start. Tried to charge battery but that didn't work. Any suggestions? Thanks in advance
I suggest that you check to make sure that your mower's blades have been disengaged. There is a safety switch that will prevent restarting if your mower's blades are engaged.
Jul 07, 2011 | Garden
Replaced blades on LT 1018 series and the blades are making a grinding noise. Followed operators manual instructions, purchased proper replacement parts. can you help?
You did what you were supposed to do, new blades, proper installation, and you were happy with what you thought was going to be a good outcome. The problem is that the new blades are hitting the deck area. Old blades ware down , your mower deck was bumping into stuff . Now you have to go under with a hammer and hammer back the dents where the blades are hitting. You did very well to start, but now to finish you have to do a little bit more. You will be mowing again in no time. Good luck.
Jun 12, 2011 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
When I finish mowing yard I disengage mower blades but they keep on turning why
May 14, 2010 | Garden
Left side of mower fell into hole while mowing - blade does not rotate smoothly and when blade spinning at full speed makes loud rattling did i bend one of the prop shafts ?
yes, it is bent, the equilibrium has been thrown off balance, unless you can hammer it back straight, I suggest replacing the blade with a new one or have a machine shop press your old blade back into shape
Aug 15, 2009 | Swisher Finishing Trailmower - 44cutting...
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
