At start up the only thing that appears is a square with a questrion mark in the middle of it
  • 739 Answers
This is a sign that the computer cannot find a valid startup drive.
You need to say which laptop and which operating system you are using.
Posted on Aug 03, 2013
A BLACK SQUARE APPEARS IN THE MIDDLE OF THE SCREEN HOW DO I GET RID OF IT
Hi Tony
You`ve mentioned that ON CERTAIN CHANNELS THE TV WORKS FINE, so your trying to say that not all channels THE BLACK SQUARE APPEARS IN THE MIDDLE O THE SCREEN... my be that black square is generated from the broadcast center. may be your unit is good. let me ask you how many channels that your tv works fine..?
Jan 16, 2014 | Panasonic CT-34WX52 34" TV
A black blank square image appears in middle of screen
You probably have turned on closed-captioning and have it set for "text" mode. Check the remote control for a button marked "caption" or "cc". As you press it, it will cycle through the settings until you reach "off" again. You might also be able to turn off captions using the front panel menu button if the TV has one, but often the remote is required.
May 05, 2011 | Konka K3290U 32" TV
How to set the timer for a self portrait on a A1000IS canon power shot
In the camera/shooting mode, press the bottom of the 4-way button and you will see the drive mode options appear on the LCD. The top icon (square) should be highlighted. Scroll with the up/down buttons to the 10 second or 2 second delay icon, and then press the Func/Set button in the middle. To return to normal, do the same thing but select the square icon.
Feb 12, 2010 | Canon Powershot A1000IS Digital Camera
Images of square subjects taper to the left
Your post is rather general, but I will see what I can do for you:
My guess is that the camera and the subject are not lined up properly to produce a square image. The same thing happens when you point the camera up at a tall building. Since the top of the building is farther away it appears smaller in the image, like the buildings taper as they get taller.
When taking a picture of a square object, you need to have the surface of the object parallel to the body of the camera in order for it to appear square in the image. Additional, most of the time, you will also have to shoot directly at the middle of the object as well.
Small amounts of this distortion can be corrected in PhotoShop.
Nov 14, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Colors dont line up, black square,in middle
with no model or make, all i can suggest is that one of the convergence amplifiers is acting up(usually there are two used in most rear projection sets) they may have to be replace at the same time to avoid doing the same thing later on. look for a heavy metal heat dissipator tha is where they usually mount.
Aug 03, 2009 | Televison & Video
My Dyson upright suddenly won't stay in the upright position. It appears that a little rubber piece has fallen out of position.
- Stand behind the vacuum cleaner and look at the right-hand side wheel
- Remove the AI PIPE (it has two purple buttons that you push together to lift it up and out - it looks like a Tuba)
- Lay the handle down and look for a black button that will be exposed in front of the square hole
- Stick your index finger and middle finger into the vacant AI Pipe Hole (the square hole)
- Reach over with your thumb and press the black button in front of the square hole
- Whilst pushing the black button, lift your index finger and your middle finger and move the gray plastic piece up (lift the square
hole basically)
- Remove your fingers from the square hole
- Lift the handle and stand your machine back upright again
- Place the AI Pipe back into the square hole
Apr 06, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
