Question about HP DeskJet 3000 Printer
Within minutes of each other, both ink cartridges on my HP Deskjet 3000 printer showed that they had failed. I replaced the tri-color cartridge with a new one I had on hand, but the same error message displayed, even after powering the printer off then on again. So it doesn't appear to be a cartridge problem. Any ideas?
    Master:
  • 966 Answers
You replaced the color cartridge. what about the black? If bothare new and properly installed, it should work. However using the tool menu, allign cartridges and clean digitally as directed. It should work. It is not the cartridge problem if they are new.
Posted on Aug 02, 2013
  • 59 Answers
SOURCE: Color Cartridge Failure
You know, I'm not going to read the other solution. I know 100% FOR SURE, when a cartridge fails, it is dead and there is nothing you can do about it, but there is a good side. HP ink cartridges have a year warranty. Call them and tell them it failed, they'll send you a new one!
Posted on Oct 02, 2007
ctf1800
  • 4402 Answers
SOURCE: cartridge failed after replacing it wtwice
unplug and plug back in?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00035736&cc=us&lc=en&dlc=en&product=305375&dlc=en&lang=en
are you sure you have the correct one in the correct slot?
Posted on Dec 21, 2007
I just purchased new hp cartidges and I still get error massage cartidge #57 needs to be replaced.
The line on the printing at the end or far right of the sentence (like the last 3 or 4 words are faded)
this is for hp 7550 photosmart
Posted on Oct 29, 2008
jmassengill
  • 345 Answers
SOURCE: The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Posted on Jan 08, 2009
SOURCE: HP Photosmart 3310 all in way Error Ink System had Failed 0xc18a0101
I had this same exact problem. Try doing:
1. Unplug the power cord from printer.
2. Hold both o.k and Cancel simultaneously.
3. Plug the power cable while holding the buttons.
After I did this my printer reconfigured like it used to do and it was like it was new again.... well new plus a headache a managed to get while reading all these little posts. I hope this helps!
If not try going to this website:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers
Posted on Sep 08, 2009
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: Inkjet411help@gmail.com
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Aug 14, 2014 | HP DeskJet F4280 All In One Printer InkJet
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    Printer (HP deskjet F4180) showing E and color
    This means that there is issue with the Ink Cartridges.
    Please remove and re-insert the cartridges.
    Check the expiration date on them. Also make sure that you are using genuine HP Cartridges, not refilled or Remanufactured.
    If the issue still persists, please replace the ink cartridges.
    Jun 02, 2010 | HP Photosmart 2575 All-In-One Printer,...
    Does not print in color although we have a new color cartridge in there and the print preview shows that it should be in color
    Ink may be new, but their nozzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
    Feb 11, 2010 | HP DeskJet 5650 InkJet Printer
    New 57 color and 21 b/w ink cartridges were installed. HP F4180 Deskjet shows blinking lights indicating both are malfunctioning. Going to Applications-->.Utilities-->Printer (and following...
    Sounds like your ink cartridges have defective electronics or the pins in your machine are dirty. You can clean the electrical contacts in your printer and on your cartridge first with isopropyl alcohol followed by water on q-tips to remove any alcohol residue. If that doesn't work then you need to replace the ink cartridges to fix the problem.
    Jan 23, 2010 | HP DeskJet F4180 Inkjet Color All-In-One...
    Ijust replaced the color cartridge and now ink lights don't work
    Are these cartridges remanufactured cartridges, or did you order them from HP?
    Try unplugging the printer power, and plugging it back in after about a minute.
    Jan 14, 2010 | HP D4360 DeskJet Printer InkJet
    Full ink catridge but light is still blinking.
    The light blinking when the ink cartridge is failed.Left lamp is for color cartridge failed, right is for black cartridge failed.Try replace it.
    Nov 12, 2009 | HP DeskJet 5150 InkJet Printer
    New tri color ink cartridge will not print red
    Probably bad, there's actually no way to check ink levels.
    Jan 22, 2009 | HP DeskJet 960c InkJet Printer
    HP DeskJet 3000 Printer Logo
    48 people viewed this question
    Seeker5211
    Seeker5211
