Question about Zenith Televison & Video
Emote control for zenith model Z42lcd4f suddenly quit responding to all commands, also will not resond to cable universal remote.
4 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
  • 11 Answers
SOURCE: universal remote codes
Most universals have a feature that automatically searches for the code. How to use it is in the remote's user guide.
Posted on Dec 21, 2008
  • 1126 Answers
SOURCE: zenith universal remote codes
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=zenith&dv=universalremote&md=zn501s&kw=&st=&ar=&dt=&so=&pg=2&file=others/zenith/zn501s-manual.zip
Unfortunately, there is no code sheet included in this user guide. However, Code Search is covered on page 10.
Posted on Sep 11, 2009
Testimonial: "thanks, took 2 minutes and i was back in action"
What is the code of zenith converter box to program with my universal control remote?
If the remote is universal, you should be able to perform a code search to find something that work with your Zenith converter. If you search through all codes stored in the remote without success, you may have to try another universal remote. Some of the newer RCA universal remotes specifically control converters and other devices.
Feb 25, 2015 | Zenith Televison & Video
Suddenly, the remotes do not control the TV i.e. power on/off. I suspect the IR sensor is bad and is it easliy replaceable
All universal remote controls have this problem. Just try to set it up with an other code. That is the only way to try.
Dec 05, 2013 | Zenith Z50PX2D 50 in. Plasma HDTV
Universal Remote Controll Codes for a Zenith TV
These are the codes for Zenith TV: 0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
Aug 04, 2012 | Big Button TV Universal Remote
I have the codes for the rzenith emote but dont know what sequence of buttons to press in order to program it
Instructions here:
http://www.replacementremotes.com/Zenith-Manuals/Download-FREE-ZNA110-Manual-Operating-Manual.html
May 21, 2010 | Zenith ZN110 Remote Control
I need the Zenith remote control code for the 1986 Zenith TV
joe, the remote control codes are not the same from vendor to vendor. I think you're trying to program a universal remote control to operate your tv, if this is so, you will need to get the model number of the universal set and refer to the product code list, look under tv and zenith, another procedure you may try is the code search, this puts out all the available codes programmed into the universal set, just follow the instructions and be very patient because like I mentioned it will take you through all the available codes untill it will send the correct one for your zenith tv.
Feb 10, 2010 | Televison & Video
I need the zenith universal remote control codes for direct tv receiver
Hi here is a link to the zenith remote code page scroll down to the Cable & Satellite section and choose the service you have....
http://www.universal-remote.net/zenith.html
Feb 01, 2010 | Televison & Video
HOW TO PROGRAM RCA RCU430 UNIVERSAL REMOTE CONTROL TO A ZENITH TV
Hello Lorielevi,
Follow the steps below.
Press and "HOLD" CODE SEARCH.
Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
Enter the three digit code from the TV, VCR or Cable Box code at the bottom.
Release CODE SEARCH.
With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
here are the code for Zenith 001 056,061,068
hope this sort you out. If it does then please leave a thumbs up
Cheers Little Dish Fitter.
Oct 16, 2009 | RCA Universal Remote Control
Cox Universal Remote Won't Work for Zenith VCR
Try the Cox website's pdf. for this universale remote. I hope this is it and good luck to you. Sincerely, CBR2009 http://www.cox.com/support/cable/pdf/universalremote04.pdf
Jul 11, 2009 | Zenith DBZN-311 Remote Control
I am trying to find a universal remote code to control the new Zenith digital tv tuner converter box. The model # is DTT900. It is for a person with low vision who cannot see the buttons on the remote...
Pls post back with the brand and model of the universal (replacement) Remote Control or what remote control you would want to use with the Zenith DTT900 Digital-to-Analog Converter Box.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 23, 2008 | Televison & Video
Televison & Video Logo
761 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
