Question about Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge
Hi, I just got an Executive 56 waterway pump
Hi, I just got an Executive 56 waterway pump (PF-30-2N22M) installed in my hot tub. I understand that this is a 4 hp pump. The spa dealer who installed the pump said it's got a one year guarentee. However, he said the guarentee is only good for the spa dealer, not the consumer. Is this true? Is there any way I can get information about my specific pump? Is there a serial number or something to identify it and when it was originally purchsed by my spa dealer?
freetek
  • 5568 Answers
SOURCE: I need to know how to remove the impellar to replace the seal.
That impeller may have been pressed on; good luck.
Posted on Aug 23, 2009
Ian  Hot Tub
  • 77 Answers
SOURCE: Leaking #1 pump on Arctic Spas Cub hot tub.
You don't need to replace the entire pump. The mechanical seal can be replaced quite easily by someone who knows what he is doing.
The only problem that you ma encounter is with removal of the pump impellor. It can take considerable force to unscrew the impellor from the pump shaft and there are special tools available to help although you may as well just leave the job to a professional. Sometimes the impellor can be seized onto the shaft, especially if it has been leaking for some time and if it's seized you will need to break the impellor off and buy a new impellor too.
I'm a spa tech from the UK and I replace these seals regularly, I'm actually replacing one tomorrow for a customer. If anyone in the UK is having a similar problem and need help please feel free to get in touch: http://hottub.synthasite.com
Cheers,
Ian Kime.
Posted on Apr 01, 2010
SOURCE: How do I remove the wet end of the pump from the
Take the screws off the outer cover fo the wet end. That will expose the impeller.
At the other end of the pump is a small metal cap in the middle. Pry that off with a screwdriver. That reveals the shaft of the motor which has a slot in it. This allows you to hold the shaft still with a large screwdriver.
While someone holds the shaft with a big screwdriver, you rotate the impeller counter clockwise to unscrew it off the motor shaft.
In my case the impeller was so caked onto the shaft with rust that we could not loosen it. We broke the impeller and still could not unscrew it. The screwdriver keeps jumping out of the slot in the shaft.
So the next step was to take the shaft out of the motor. On the far end of the motor are 4 small looking bolt heads. Undo those. They go right through the motor into the 4 legs of the wet end.
Stand the motor up with the wet end up. Pull hard to pull the wet end motor cover off the motor and you will then have the wet end and armature of the motor in your hands. Heavy.
Place some wood into a large vice and then grip the big silver part of the armature in the vice. Then unscrew the impeller.
Posted on Jan 27, 2011
SOURCE: I have a Waterway Spa
the problem with the sound is the bearings inside the motor are going out. i have the same pump and i have to replace the motor. replacing the bearings is very hard and will cost you about the same after you carry the motor and new bearings to a shop to be pressed in. hope this helps!!
Posted on May 06, 2011
cmdill
  • 3 Answers
SOURCE: my new waterway executive 56 4 hp dual speed motor blew a 30 amp fuse when i started it for the first time. what is the problem ?
OK 750 watts per HP = 3000 watts or about 30 amps at 115VAC. You will need 40 amp breaker for that pump and No. 8 wire between the breaker and pump if you are using 115VAC. The inrush current on the motor would be high enough to trip a 30 amp breaker.
On the other hand, if it is running on 220VAC you may have the motor wired wrong. Read the instructions that came with the motor.
Posted on Jul 12, 2012
What is the flow rate (GPM) of an Executive 56 Waterway pump Model PF-50-2N22F?
Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C
Features:
  • Executive spa pump wet end designed specifically for 56-frame spa motors
  • Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
  • Two speed spa motors have four sets of insulated windings for increased efficiency
  • 56 frame spa motor for added strength, cooler operating temperature and longer motor life
  • Large 2-1/2 inch intake for improved flow performance and reduced noise
  • Large 6-1/2" diameter wet end for higher head pressure
  • Split capacitor, (start and run) for less energy consumption
  • Thermally protected to extend life expectancy of hot tub motor
  • Highly versatile wet end can be rotated every 90 degrees
  • Viton seals
  • Three year manufacture's warranty on spa motor and spa pump wet end
Jun 05, 2015 | Waterway Garden
Cant get face plate back on, for my Executive 56 Hot tub pump
these plates have notches that line up with the housing..it may be backwards or need spun a bit to"lock in"
Oct 26, 2013 | Waterway Pool & Spa
Need to change seal on pf-40 waterway pump
can change but water leaking into motor it will start to squeal bad bearing just change whole pump
Dec 26, 2012 | Waterway 5HP Executive 56 Frame Spa Pump...
I have a Waterly Executive Pump PF-40-2N22C\r\nI
Waterway did change the wet ends slightly (the difference is only minute and you wouldn't realise without meausring) and if yours is the older version you may need to change the entire wet end.
I'd advise you to take the pump to someone who can advise you and perhaps consider changing the entire wet end so that you have a new mechanical seal too.
If you're in the UK I can possibly help but I suspect that you're in the US...
Regards,
Ian.
Jun 04, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
My wet end is leaking from the backside.
I have a executive 56 frame 4 hp water way motor - PF-40-2N22C. Wet end was leaking at shaft, had it fixed and now the motor won't rotate at all. shaft is free it just hums. Checked supply voltage and the voltage at the connector. All is ok, what do i do now.
May 21, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge  Logo
118 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
