Question about Garden
TURN KEY AND ENGINE TURNS OVER HALF WAY AND STOP LIKE THE BATTERY IS DEAD BUT ITS NOTDEAD NEW BATTERY.
    Top Expert:
  • Garden Master
  • 50,503 Answers
Check for a problem in the combustion chamber like a stuck valve or the plug is too long hitting the piston. Other than that if the big end cap bolts are loose they will be hitting on the crankcase.
Posted on Aug 03, 2013
No power to car key wont turn
check the alternator and check for a short or ground a wire may be touching the frame you may want to check the engine computer module
Feb 17, 2014 | 2004 Mercedes-Benz S 430
2000 Hyundai Excel ignition lock problem
What most people refer to as the "Ignition switch" is really the "cylinder lock", that when turned with the key, operates the actual "ignition switch".
The switch causing your problem is inside the steering column, and the column needs to be at least partly disassembled to access it.
Jan 25, 2014 | 1994 Hyundai Excel
Won't start
so stop guessing, buy an $10 voltmeter (walfart has one)
and do simple tests. all very easy, ask.
the first step is jumper cable starts, ! cranks/ pass/fail??????
my guess, this fails.
if my car dont jump start, (i can coast start my car)
i check battery voltgage, alhhhhhh 12.6vdc, good. 10v bad.
i then hot wire the starter solenoid.
dead, (or clicks) , starter bad, big cables to it bad,(x2) or engine seized. (or battery bad, blow 10v cranking is bad battery 99%
i hand turn engine by hand, it dont turn, it's seized.
it turns by hand; good.!
so lets say the hot wire test works (keys in pocket cranks but dont start now , because my keys are in my pockets for safety)
that means the KEY LINE Is dead (small wire to starter solenoid)
see here. works for all cars. (not hacked key lines, etc.)
http://www.fixkick.com/nocrank.html
Jan 19, 2014 | 2000 Toyota Camry
Everything is dead
Hi eyansdaddy,
Sounds like a bad connection on the battery , check the earth cable on the battery and the one that earths the engine to the bodywork (at the bottom of the engine) if there worn or frayed it can stop the engine from starting. all the best Scott
Aug 22, 2012 | 2002 Chevrolet Silverado 1500
Battery is new, engine won't turn over.
The voltmeter should only go as high as 14-15 volts when the engine is running. I would check for a poor connection between the battery and starter.
Oct 10, 2017 | Jeep Grand Cherokee Cars & Trucks
Drive 2007 grand prix. wont even turn over or click.lottsa batery. Everything works. Just wont start or turn over. When starts and I drive it, then stop and turn off,sometimes wont start. Half to sit a few...
SOUND LIKE ALTERNATOR NOT CHARGING BATTERY.CHECK BATTERY VOLTAGE SHOULD BE 12.6 VOLTS.MAY SURE BATTERY CABLES CLEAN AND TIGHT.WITH ENGINE RUNNING CHECK ALTERNATOR OUT PUT AT BATTERY.SHOULD BE 13.5 - 14.5 VOLTS WITH ENGINE RUNNING.IF ALTERNATOR FUSE GOOD AND ALTERNATOR BATTERY FEED WIRE AND VOLTAGE REGULATOR WIRES OKAY NOT DAMAGED.DRIVE BELT NOT SLIPPING OR BELT TENSIONER NOT DAMAGED.ALTERNATOR MORE LIKELY FAULTY.TURN OFF RADIO FIRST.BEFORE REMOVING NEGATIVE BATTERY CABLE TO KEEP FROM LOSING RADIO CODE.
Apr 10, 2011 | Pontiac Grand Prix Cars & Trucks
Battery went dead, charged battery and still wont turn over
i had a 95 xj 6 with the same problem. At the fire wall on the right side is a bolt with a rubber cover on it. this cable goes behind the engine to the starter. That bolt at the fire wall my need to be replaced. find it it may be rusted or corroded. If it is, the current from the battery will stop at that bolt and not contunue on to the starter but lights and everything else will work. If when you turn the key you just hear a click or nothing. that part is 5 dollars at autozone.
Mar 10, 2010 | 1995 Jaguar XJ6
2003 Mitsubishi Eclipse; Started then Died
Sounds like the battery is the problem. It's losing power buy a poor connection and the car's computer is trying to reset itself. Replace the battery and the cables.
May 01, 2009 | 2003 Mitsubishi Eclipse Coupe
95 F150 wont crank
the starter should be replaced. The solenoid is kikcing the pinion out but there is no contact being made to turn the starter motor. I have the exact same truck and before i changed the starter used the old starter tap trick. Tap the starter casing with a hammer and it should start turning again. hope this was helpful for you. Good luck.
Sep 16, 2008 | 1995 Ford F150 Styleside Regular Cab
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
