Question about Husqvarna Rz4623 46" Ztr Lawn Mower Zero Turn 23hp Kohler Engine
My mower is running fine. However, when the blades engage, they run for a little while and then stop. Then after a few minutes, they will roughly start again before quitting again. I have adjusted (tightened) the deck belt, but it hasn't helped.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
Make sure the blades spin freely. Replace the deck belt.
Posted on Nov 18, 2013
SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Posted on Mar 31, 2009
SOURCE: I have a Husqvarna 23hp 48
not sure but is battery being charged the right way have seen battery's put in and charged backwards
Posted on May 15, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
SOURCE: the engine run rough and backfires when deck is lowered with pto
It sounds like your blades may be restricted when you lower them. A possible solution for this problem would be to remove the mower deck and clean out all the dead grass buildup inside the housing.
Posted on Jun 13, 2009
  • 420 Answers
SOURCE: Mower blades willnot engage
make sure the battery is fully charged, check all electrical connections and clean them with vinegar and rinse well with demineralized water afterward.
Posted on May 27, 2010
Exmark lazer HP 19 Kawasaki 50" deck new PTO and new relays blades engage for 30 minutes then shut off engine on. After cooling will engage for 10 minutes then shut off
Engine valves need adjusting.
symptoms: starts ok, runs until engine reaches max temp loses power then stops. can't restart when hot. once restarted runs for a while stops again.
There is very little clerance in these valves and temperature alters the lenth by a few thou and the valve don't close fully losing compression, once cold the valves shrink back enough to create enough compression to start again.
Aug 13, 2015 | kawasaki Garden
Why is the engine running rough after a few minutes and the spark plug gets carbon on it?
Could be your choke is not shutting off like it should and some mowers the choke is on when you put the throttle wide open. Cut the speed back just a little and see if that helps.
Aug 01, 2015 | Garden
I was mowing and the blades stopped turning. I disengaged and re-engaged the blades a few times and they started back. Then a few minutes later the blades stopped again then the motor stopped and will...
I have no idea what type or model of mower you have but if I was to guess I would say it has an electric pto clutch on it, if so remove your pto belt and clutch. I would bet it is burned out and locked up preventing your motor from turning over. Once the clutch is removed I will bet it will start and run fine. This is not a cheap fix but relatively easy one. Hope this helps.
Aug 21, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
We have a John deere 314 lawn mower. After you mow a few minutes there is a loud pop and the mower stops running. After it sets just a few minutes it will start right back and mow a few more minutes and...
Julie this sounds silly but try and run it with the exhaust and muffler removed. If it ticks over and then stops when it's engaged for a few minutes it sounds like its suffocating.
Sep 07, 2013 | Garden
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Lawn mower running rough
adjust the carby. also u might want to replace the diaphragm in the carby. might work wonders
Mar 31, 2010 | Mtd LAWN MOWER PART # 791-180705 Assembly,...
Poulan pro 20hp 42" lawn mower running rough
My immediate impression is that the float is "stuck open".
Pull the float-bowl, and check that:
a. the bowl and float are clean, and
b. the float moves freely, and
c. when it's in the "up" position, the flow of gas stops (which means that the needle is "seating" properly and doing its job)
Sep 04, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Lots of smoke when I engaged stuck blades - now runs roughly
Most likely what you did was burn one or more spots on the belt. When the blades and belt stop turning, like in tall grass, the engine doesn't stop and will burn flat spots on the belt at the engine pulley. Every time the flat spot hits a pulley, it will jump and can set up a bad vibration. Run your hand around the sides of the belt or take it off and you will feel or see the thin spot(s) on it. Replace belt.
Jun 09, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Poulan Pro riding mower jerks in forward and the blades engaged
This is a lawn mower catagorized as a chainsaw. We don't answer lawn mower questions ands you don't cut down trees.
Mar 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Husqvarna Rz4623 46" Ztr Lawn Mower Zero Turn 23hp Kohler Engine Logo
402 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
