Question about Centon ELECTRONICS UNIVERISTY OF MIAMI MOUSEPAD"
Can I use my Mikomi LK-802A keyboard & mouse on windows 7. I've tried several times to install drivers but cannot find any thats compatible. Does anyone have any suggestions?
I have upgraded the O/S to Windows 7. Impossible to load a work:(
Try installing the driver in Compatibility Mode. Right Click, the main .exe, then simply choose compatibility Mode for XP SP2
May 26, 2010 | EzKey EZ-8000 Smart Office Keyboard
Belkin bluetooth mouse unable to work with windows 7
try installing the driver for mouse in a compatibility mode....
rightclick on driver file >properties >select compatibility tab > check mark in the checkbox "run this program compatible for" and select windows xp....
guess it ll work fine....
good day....
Mar 03, 2010 | Belkin Bluetooth f8t041-b Mouse
Mikomi mouse
An optical mouse works based on imaging principle so we have the freedom of accessing even in a 3D way. If your Optical mouse is not moving the cursor side wise, I would suggest you to look for the exact Mouse driver and install it. Usually on a Windows XP machine they work as plug and play.
If the Driver is working fine, you must look for the Windows or OS compatibility. The WDDM compatibility can also cause this to happen.
Else you have to replace the mouse.
Good Luck.
Feb 16, 2010 | Dynex Wireless Optical Mouse
Not compatible with new computer windows 7
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Jan 24, 2010 | Microsoft Wireless Laser Desktop 4000...
Cant install mouse
mouse may not be compatible
what os is the laptop
Feb 08, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Mikomi
just install the mouse drivers, and then follow the hardware installation. 1. Turn on PC wait for windows to load 2. Insert the USB Plug of the receiver 3. Press the small button on the mouse & Keyboard 4. Press the button on the receiver. then the connection between the mouse and keyboard will be established. Press keys and Move the mouse to see if the connection is ok.
Jun 04, 2008 | Micom (VIP-4004-ISO-DX) (VIP4004ISODX)...
Mikomi wireless keyboard
Mikomi doesn't have its own drivers. You can try using Logitech Setpoint (any version works)
http://www.logitech.com/index.cfm/support_downloads/
downloads/&cl=us,en?selectedcrid=398&selectedcid=152#
Download the one that most resembles your mouse. You can see the various mice from the drop down menu or choose the one that you see in this link..
Apr 11, 2008 | Computers & Internet
Don't run the setup program. Instead reboot your computer and use the windows add hardware wizard to install the drivers from the CD. The windows hardware wizard will detect several different devices, allow it to install them all from the CD.
Dec 01, 2007 | Gateway 2520915 Keyboard
How to install mikomi wireless key board
I bought a wireless mikomi keyboard and mouse on my pc which has windows vista operating software, but the keyboard is not working , no light is showing. lettiesmall
Nov 17, 2007 | Computers & Internet
Centon ELECTRONICS UNIVERISTY OF MIAMI MOUSEPAD" Logo
23 people viewed this question
Top Centon Computers & Internet Experts
David Payne
David Payne
Are you a Centon Computer and Internet Expert? Answer questions, earn points and help others
