Question about FAVI Televison & Video
My FAVI L3226EA-WH won't start as it should. I have to press the button on the side of the TV 5-10 times before the start holds a picture. Is it possible the capacitors are leaky, unable to hold enough charge for proper start of the TV? The set runs perfectly all day and night once it is running. If I shut it down for a few minutes and it is still warm, it will often start on the first try. What part will solve this problem?
    Top Expert:
  • FAVI Master
  • 75,017 Answers
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Jul 07, 2017
I pressed the sleep button by mistake and now dont have a picture
It is importat to know the TV model but in some cases the following procedure solve the problem: Press and hold the power button on the TV (not the remote control) and while the lights are blinking, press and hold the menu button on your TV at the same time. You can find the TV button at the rear right side in most of the models.
Jan 06, 2014 | Televison & Video
RCA LCD TV locked up.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Aug 12, 2012 | RCA RCR312W Remote Control
I have an older Lutron system - the Maestro Wireless MRF-VCTX-WH. I can't find instructions to reconnect one dimmer. The only instructions online that I can find are for the Pico, and that process doesn't...
Hard a hard time finding it too. Found an old instruction sheet lying around:
Step 1) Turn the Dimmer On
Step 2a) Press & hold the Dimmer's tap button. LEDs will blink one at a time, from the bottom up to the top. After approximately 8-seconds, the LEDs will start to cylce slowly from top to bottom (setup mode). CONTINUE to hold the tap button and go to step 2b.
Step 2b) Press and hold the "ON" button on the Wireless Controller (MRF-VCTX).
Step 2c) Once the dimmer learns the wireless controller, the LEDs on the dimmer will cycle quickly from top to bottom. Release the dimmer's tap button to exit set-up mode, and release the wireless controller's on button.
Repeat steps 1-2c for each additional dimmer.
Apr 24, 2011 | Lutron MRF-VCTX-WH Maestro Wireless White...
My tv wont come back on fpa lock on
Press Menu Button from any Remote control ( RC) by which could turn on your TV, press menu , menu drop down list will be visible on ur screen then wait 4 a minute or more till ur RC stop blinking , then go to Preference menu , go to FPA lock, turn it off. enjoy.
Apr 21, 2011 | RCA 20F420T 20" TV
When I turn on the TV the blue indicator light comes on but there is no display, then the blue light starts blinking.
The following steps should be able to correct the problem:
1) Unplug the TV or remove AC power from the TV
2) Count to ten and then plug in the TV
3) Locate the [Menu], [VOL-] and [Power] button on the TV’s side panel
4) Using the buttons on the TV’s Side Panel, press and hold both the [Menu] and [VOL-] buttons.
5) While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [VOL-] buttons.
6) The TV’s lower left Blue Power LED will come ON.
7) Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time.
8) Press the [Mute] button on the TV remote twice
9) Unplug the TV or remove AC power
10) Count to ten and plug the TV in
11) The TV power should automatically come ON and the blue power LED with be ON
12) Wait 40 seconds and the TV picture should appear
13) You can now continue using your TV.
14) If the picture does not appear, power on the TV manually:
· If the LED begins flashing, unplug and power ON a second time.
· If the LED begins flashing again, power ON the TV without unplugging
If the LED begins flashing again, contact us directly by phone to obtain a local authorized service center for you.
If the TV does power on, please reply back with the software version number for us to research this issue. Please follow these steps to obtain the software version number:
1) Press the [Menu] button on the remote control.
2) Using the arrow keys in the center of the remote, scroll over to the "settings" menu and select the [OK] button on the remote
3) Scroll down to "system info" and select [OK] button on the remote
Dec 19, 2009 | JVC Televison & Video
I turn on the T.V. and the blue light is blinking and the T.V. doesn't turn on
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
Jul 10, 2009 | JVC LT42P789 42 in. LCD TV
The picture on my LTV-19w3 WH tv just shows a blue, black, or green screen with about a 4" sq. plaid patch in the upper right hand corner. Sometimes the sounds works other times it does not. Can anyone...
While the TV is on do the following:
1. Press the "Right Arrow" button on the remote.
2. Press the "Left Arrow" button on the remote
3. press the number keys in order, 1-9
I believe you are in the TV's service menu and the Blue/Green/Black are just test patters. If so, pressing these keys will eventually change the pattern..
Get to the main page of the service menu and press the [power] button on the remote.
Jun 16, 2009 | Westinghouse LTV-19W3 19 in. LCD...
My tv won"t turn on.
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Apr 07, 2009 | JVC LT-42X579 42 in. LCD TV
TV Stuck in Demo mode
In the tv and with the set turned on press and hold the ACTION and CHANNEL UP buttons at the same time for more than 5 secons.Let Us know how it goes.
Oct 16, 2006 | Panasonic CT-34WX54 34" TV
Televison & Video Logo
48 people viewed this question
Top FAVI Televison & Video Experts
Are you a FAVI Televison and Video Expert? Answer questions, earn points and help others
