Question about Liebert Computers & Internet
When i plug it in to the power source outlets it beeps continuously non stop beeping
glassmanATL
  • 11 Answers
SOURCE: Power keeps going on and off
I have the same problem.
It is most likely the battery.
I tested my battery on a Shumacher trickle charger, and the battery wouldn't hold a charge.
This is a common problem with UPS systems that use sealed lead acid batteries.
The longest life that you can expect with these types of batteries is 5 years MAX.
The battery can be replaced with a Radio Shack 12V/7200mAh Lead-Acid Battery
Model: CNB-GP1270F2 | Catalog #: 23-9030
Here is the link for the UPS users manual.
http://www.cyberpowersystems.com/user-manuals/CP550SL_UM.pdf
To replace battery, (unplug AC cord), turn the UPS upside down on floor or workbench.
Remove the 6 deeply recessed phillips screws, then pull the bottom off.
Remove the wire leads from the old battery (pull on the connectors, not the wires). Install new battery (red wire to red or + sign) and replace the bottom and screws. Careful, tighten the screws finger tight (plastic strips easily).
Plug in UPS and you should be good to go.
Hope this helps
Posted on Oct 27, 2008
erwinroyo
  • 189 Answers
SOURCE: continuously beeping
Was the ups charge? If it was not charge, have charge for a couple of hours means that with no computer attached or computer off.
If still continues have a new battery.
Thanks
Posted on Dec 06, 2008
SOURCE: Has started to beep whenever items plugged into
If it's more than 3 years old, you probably need new batteries.
If the beep started after plugging anything additional into the UPS, you may be in an overload state, and the beep is telling you that it's choosing to beep and not function as intended rather than smoking itself. Try unplugging a piece or two from it and see if the beep goes away. If not, probably just you're batteries giving out due to old age, they'll only give you 3-5 years.
Posted on Nov 06, 2009
nicarta
  • 506 Answers
SOURCE: beeping!!
Check the back of the UPS to see if the fuses/breakers are properly closed or open.
Posted on May 28, 2010
Light Yagami
  • 29 Answers
SOURCE: continues beeping
did you leave it plugged in to let it charge? ups's will beep continuosly till they are charged, if it has dead battery packs inside, it will continue to beep because there is no battery charge to support its job. leave it plugged in for 2 hours. if it doesnot stop beeping, toss it and get a new ups
Posted on Jun 04, 2010
Long beep on gateway computer
pls find the model no. and find the beep codes and match the order to identify the problem
ex:POST Beeping Error General Codes
  • Bad Motherboard - 1 long and 1 short beep
  • Disk drive related problem / Video card problem - 1 short beep then nothing happens
  • Bad video card - 1 long and 2 short beeps
  • Bad power supply - 1) continuous beeps, 2) non-stop short beeps
  • Bad memory - 3 short beeps
Nov 07, 2016 | Gateway Computers & Internet
Samsung rb215abbp won't stop beeping. I recently switched the door from the right side to the left. Now my fridge says 66 degrees but is cold. Light is on only when I unplug and plug it back in.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Sep 30, 2016 | Samsung Refrigerators
Samsung refrigerator alarm beeping continuously
May 15, 2016 | Samsung Refrigerators
I have a frigidaire side by side model GLHS37EHSB7 refrigerator makes a continuing beeping sound what could be wrong?
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 11, 2015 | Frigidaire Refrigerators
My gateway dx4860 ub33p is making 1 long continuous beep at start up not showing anything
Unplug power cable
Hold down the power button for 10 seconds
then remove power cable from the back of the computer and plug it back in.
try plug it directly to another outlet
that long continuous beep is a power issue
if you originally had it plugged into a power protector or multiplug connect it the outlet directly to get better power.
Jun 15, 2014 | HP Compaq dx2300 Microtower - RT950UTABA...
Machine will not boot-up.....beeps 3-3-1.....please shed some light on the subject
do you know the make and version of your BIOS?
  • 1 long and 1 short beep = bad motherboard
  • 1 short and nothing else happens= disk drive/video related problem.
  • 1 long and to short beeps = bad video card
  • 1 continuous beep or non-stop short beeps= bad power supply
  • 3 short beeps = bad memory
if you can tell what you are trying to do i may be able to help further.
Oct 08, 2010 | IBM ThinkPad A21m 2628 Notebook
When you turn on the computer it makes a series of stringed beeps for a second also when turning it off, keyboard and mouse does not work
what's the beep pateren it does? here is the basic beep codes:.....
Error Code: Faulty Component:
1 short beep None (Normal Boot)
2 short beeps POST error
Non-stop beep Power supply or system board
1 long beep and 1 short beep System board
1 long beep and 2 short beeps Video card
1 long beep and 3 short beeps Memory
3 long beeps Keyboard
Non-stop short beeps Power supply or system board
(a key on the keyboard might
also be stuck)
None Power supply, system board,
or system case built-in speaker
Oct 01, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Continues beeping
Jun 04, 2010 | CyberPower 575SL (CPS575SL) UPS System
My PC randomly starts to beep continuously. I say randomly as it can start beeping at anytime, including when the computer is switched off and not being used. I can pull out the power cable and the beeping...
Try replacing the RJ45 LAN cable. It may have a short in it. Also check the metal back plate. Each opening has small 1 or 2 tabs that ground each port.
The MB's internal speaker must have power in order to beep. Since you have pulled out the power cable there can't be any Standby power to the MB which keeps the cmos battery charged while the system is off. However every RJ45 does carry a low amount of voltage through the cable. If the above doesn't help there is one other thing you can do;
Go to Device Manager and "Show Hidden Devices".
Under "Non-Plug and Play Drivers" you'll see an item named "Beep".
Disable that and the "random beeps" disappears.
Once done, of course, you can hide the hidden devices again.
Cheers'
Mike
Feb 07, 2010 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
Top Liebert Computers & Internet Experts
Computer Links
Marco De La Fuente...
Are you a Liebert Computer and Internet Expert? Answer questions, earn points and help others
