Question about Video Cameras
I need to know how to use a geneva pf 740 video head cleaner I got from a friend.
What is wrong if my Frigidaire front load dryer
Thank you for your inquiry, friend!
I understand that your Frigidaire dryer has been providing you with an error code "PF". Typically "PF" stands for power failure this can happen if power is shut off during a cycle or the dryer receives insufficient power, which could be an issue with your power cord or control panel. Let's perform a reset on your dryer and you can do this by unplugging the power cord for ten minutes. If you need any additional assistance please feel free to reconnect. -Matt
Oct 14, 2014 | Dryers
I need to know some of Ronald Reagan's interesting facts
Jack did you put that Geneva incident about Prince Hussein 's fish bowl that young prince asked Mr Reagan to take care of? Pres. Reagan was staying at the Aga Khan's villa in Geneva. Please verify dates and complete story as I don't recall.
Jan 31, 2014 | Health & Beauty
Rough idle in 740 1990 Volvo Smooths out a bit when driving
When it idles rough it could be several things but, an easier thing you can do 1st is cleat the throttle body of any carbon(black stuff) with throttle body cleaner or something like carb cleaner. Ive used brake cleaner sometimes. But yea, look up your cars info about your motor and just clean all the black carbon off of anything at the throttle body and you may even need to take some of it apart to get down in there with a rag, little cleaning brush and the cleaner. Clean the thing you can move by hand called a "butterfly".
Jan 03, 2014 | 1990 Volvo 740
Hi, how is the best way to clean the lens of the Olympus C-740? I have a fingerprint on it. Is it really true that I have to buy lens cleaner or can I just use a microfiber cloth? Will cleaning it ruin...
Photo lens cleaner and a microfiber cloth used gently will work. A handier solution that you could carry with you is a product called "lenspen". If there's a photo store nearby, they would have it in stock. You could also find one at amazon.com
May 08, 2010 | Olympus Camedia C-740 Ultra Zoom Digital...
My Epson 740, don't print, I have change the cartrige, clean the injectors, but nothing. How I can solve it? Thx
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 29, 2010 | Epson Stylus Color 740 InkJet Printer
Camcorder is eating tapes (or tapes are getting stuck)
Hi ; this problem is a miss alignement off your tapthern and you may replace the pinch roler assy
and a good head cleen up
and that should solved the problem garanty
hope thats will help have a nice day
Mar 04, 2010 | Canon ZR10 Mini DV Digital Camcorder
Geneva watch bracelet
I Have a Geneva Made Pga Tour Partners Club watch that needs a new band and I have not been able to find one.It is a special band and the PGA partners club says they are no longer available and were not helpful in finding a band.
Apr 01, 2008 | Geneva J06345 Wrist Watch
Multiple problems with camera operations.
I have been searching for a solution to the same exact problem for a long time. I just found this site recently and it has confirmed what I needed to know: 1. Buy a head cleaner to clean off the head (which records and such) 2. (If 1 Doesn't Work) Don't bother getting it fixed by a business (as opposed to a friend who would try fixing it for free) because they will charge $200 to $250 for it when it only costs around $270 from Sony now. So trash the camcorder and buy a new one. That's all I know of.
Jan 21, 2007 | Sony Handycam DCR-TRV280 Digital Camcorder
Video Cameras Logo
50 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
