Question about Hitachi 57SWX20B 57" Rear Projection Television
Hit power button, turns on/off right away? - Hitachi 57SWX20B 57" Rear Projection Television
I have a canon t3i. The menu doesn't turn on when you turn on the camera.
The menu doesn't display when you switch on. You should get the settings screen appear. Once powered up just hit the MENU button
Mar 02, 2015 | Canon EOS Rebel T3i 600D SLR Digital...
Laptop won't turn on. I press the power button and it seems to turn on but the monitor remains black and the light on the power button does not come on
This version of the DELL XPS has a graphic and motherboard issue that will cause the system to turn on and turn off right away.
You can try to hold down the F key or the Fn key then hit the power button to see if you get diagnostic codes.
other than this, i woudl bet the motherboard is bad. I have seen this in 2 motherboards from this unit in 2 months as well as foudn that this is a major complaint of this unit.
if you don't have a warranty then your best bet is seenign if you can buy a board or take it to a tech shop
Feb 12, 2010 | Dell XPS M1530 Laptop
Tv doesnt turn on at all
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. The noise is what gives it away. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Jan 23, 2010 | RCA Scenium D40W20 40" Rear Projection...
How do i search for an unlisted code for my universal remote?
This is the web site where I found the codes for mine, http://www.remote-codes.com/universalcodes.htm
Hope this helps, if not, let me knoe the model # and I can assist further...
Sep 17, 2009 | Philips Universal PH301S Remote Control
External buttons not working and battery acting up
Same with me! My OK and # buttons constantly stop working X-X I just have to hold them down, keep hitting them, or hit them with another button. But usually Ill have to open the phone.
May 29, 2009 | Verizon Communications enV2 Cellular Phone
Blown Fuse
It's drawing too much power. Maybe a short in an amp. Do you have any warranty left? Double check to make sure you have the right fuse. You might also try a slow blow fuse so  you can turn it off right away as soon as the fuse starts to glow to help in diagnosing.
Apr 23, 2008 | Harman Kardon HK 3370 Receiver
Printer Anamoly?
when turning ON your printer and you hear that is going to print HIT the cancel button right away and then go to the menu see if you see a setting named DEFAULT hit that , turn off printer ,wait a couple of seconds a turn on again , it should stop printing automatically, hope it helps
Mar 24, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hitachi 57SWX20B 57" Rear Projection Television Logo
18 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
