Question about Home
Hard water ring around toilets - Home
    New Friend:
  • 20 Answers
Clean with CLR or vinegar
Posted on Aug 04, 2013
Leaking water at bottom centre both sides atbottom of base
call a good plumber your wax seal has gone the trip
Apr 13, 2015 | Home
It leaks water on the floor around the base when flushed. Only leaks when flushed Godfrey
The wax ring seal on the bottom of the toilet has let go. It isn't tough to fix. Two nuts hold the toilet down. Shut the water line in back off, take the 2 nuts off, and move the toilet aside. You;ll need a new wax ring, so you'll have to scrape the old one off. It will show you how to set it in and set the seat on. It only looks tough, but it's actually simple. Good luck!
Mar 18, 2015 | Home
Vitra
Install wax ring around base waste pipe. Make sure that 2 bolts are sticking out of a track under the toilet.Put toilet bolts through toilet holes and tighten nut with washer on each bolt to lock down the toilet. Now attache the water line that goes into toilet and bidet.
Apr 09, 2014 | VitrA Home
It is leaking around where the pipe inserts into the toilet
try a new o ring inside the the tighten nut which is attached to the water pipe
Dec 17, 2012 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Brown ring in my toilet
The brown ring is usually caused by hard water stains. With bit of chemicals scrubbed with a scouring stick. Toilets are fairly cheap if you need a new one for better looks.
Sep 16, 2012 | American Standard Home
Kohler one piece toilet. it is leaking around the bottom of the toilet but if I put the water in the back of the tank myself, it doesn't leak
if its leaking from bottom of toilet on the floor. its the wax ring that may be bad, if it does this when flushing it is either cracked or the wax ring under toilet is bad.
Mar 26, 2012 | Kohler Home
I wont to replace the sealant from around the tiolet waste pipe, what is the best way of doing this?
turn water supply off to toilet and disconnect water line from bottom of toilet tank. flush toilet to drain tank, use towel to soak up water inside that didnt flush.remove the 2 bolts ( 1 on each side of toilet), lift toilet up and move to one side and lay on it side, scrape off old wax ring from bottom of toilet, scrape off excess wax from pipe on floor. install new wax ring over drain pipe. stand toilet upright and lift straight up over drain hole and reset slowly to make sure each bolt goes through the holes on toilet, replace nuts and washers on toilet and tighten. hook water supply liune back up and turn on water.
Aug 30, 2011 | Home
When the toilet is flushed water comes out from under the toilet bowl
The wax ring has gone bad. If the toilet moves when you set on it you might try snugging down the bowl bolts on both sides but be very careful not to go to tight you will brake the bowl.
If you decide to try to fix this your self with you buy a new wax ring buy the one with the horn in it they seal better.
Jan 31, 2011 | Home
Problem: when I flush my toilet most often the water swirls around and doesn't flush. I've tried bending a coat hanger and snaking it through the exit hole to see if there was an obstruction. Any...
This is a job for a plumber unless you have a ladder. The vent pipe may be plugged or the trap in the toilet may be plugged up but this requires removing the toilet from the floor which is not that hard. two floor bolts and and turn off the water valve and disconnect the water hose then lift the toilet up and see if there is blockage by poring a gallon of water into the drain pipe. if it backs up you need to snake out the main line. You can rent a electric 25 foot snake for 35 bucks but then you have to reinstall everything plus buy a new wax ring which is about 5 bucks. if the pipe is clean and drains fine then you need to run water into the toilet outside to clear the throat of the toilet if there is no blockage then the vent pipe may be plugged and that you have to get from the roof. Best bet is call a plumber.
Jan 05, 2010 | American Standard Colony 2388.012.222...
How to Install Toilet
It's not terribly complicated, assuming that by "install a new toilet" you mean where there was alredy an existing toilet. First, remove the old toilet. Shut off the water supply valve, and flush the toilet. Then use a spone to get rid of the water that remains in the tank. Remove the nuts on the two bolts at the base of the toilet where the toilet meets the floor. These are usually hidden under two plastic caps. Now gently rock the toilet until it comes away from the floor. Get help to carry it out. Clean up the old wax that's around the flange where the pipe disappears into the floor. Don't be a wuss, it's only wax. Now you'll need the new toilet, a new supply line, new mounting bolts (don't reuse the old ones) and a two wax rings. Yes, I said two wax rings. You'll see why in a minute. Assemble the new toilet according to the instructions provided. Now here's a warning: Do NOT overtighten the bolts the hod the tank to the bowl. You're dealing with ceramics here, don't break them. Now, put the new hold-down bolts in place on the flange. Read the insturctions that came with the toilet, but you have to do this NOW. Now you'll need a helper. With the toilet upsided down, unwrap a wax ring. Make sure it's room temprature or it won't seal. Press the wax ring around the outlet flange on the base of the toilet. Now you and your helper carefully turn the toilet over without crushing the wax ring. Lift the toilet and slowly lowe it so the wax ring is centered over the "flange" which is where the sewer pipe goes into the foor. Then press the toilet firmly in place. Now if you're like most people, you screwed up here and crushed the wax ring without being centered on the flange. That's why I told you to buy two. Now you know what not to do, scrape off the first one and start again. When you've got the toilet sealed on the flange, connect and tighten the nuts on the bolts. Now you may have to use a hacksaw to cut off the remaining ends of the bolts so you can get the neat little plastic caps to fit. Now connect the water supply line. Now's where you start praying. Turn on the water and let the tank fill. Check the supply line for leaks. Fix as necessary. Now flush. Is water running out from around the base of the toilet? No? Good, you got a good seal. Yes? Very bad. Time to go back to the home center for yet another wax ring. Repeat the sealing process and get a good seal this time.
Aug 27, 2008 | Kohler Santa Rosa K-3323-0 White Compact...
Home Logo
46 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
