Question about Philips 64P8341 64" Rear Projection Television
Tv off by itself
The tv will play for a while and then it turns off by itself and will not come on again; will not respond by remote or the off/on button
  • 3 Answers
Re: tv off by itself
It may need a new lamp. Check the manual for indications like the power button flashing.
Posted on Sep 01, 2007
0 characters
3 Points
WS-5551 only on/off button works, won't respond to remote at all
take off the speaker grill, you will see 2 wire plugs, turn the tv on, disconnect both plugs, if it now works with the remote then you need to replace all of the front switches, or leave them unplugged and use the remote, if this doesn't work, you have a bad dm board or signal module which could get very expensive.
Sep 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
My new LG LCD TV (3 days old!) suddenly started playing up, last night. I was initially using the receiver unit (with built-in DVD) to play a disc of MPG files, which it did successfully. Then, I tried to...
Good thing the tv is under warranty, theres no magical fix for a problem like this. I would either return it to the store or call for service. If you atempt to do to much to fix it you might voide the warranty, and you should have to do anything to fix it as you said its 3 days old.
Tim Nolan
Sep 24, 2008 | Projection Televisions
Problems after power outage
I figured out I could still get the TV Menu so I pressed that and then I pressed 123 and it did a TV reset and then it was working again.
Aug 05, 2008 | Mitsubishi WD-52628 52" Projection HDTV
TV does not respond to Remote
follow wire from sensor inside tv to tuner board and resolder.
Apr 04, 2008 | Zenith E44W46LCD 44" Rear Projection...
RCA 52927
Solder Bridge on power switch to ground SW13201
Dec 10, 2007 | RCA P52926 52" Rear Projection Television
Tv not responding to remote and now will not turn back on!
if the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at if this helps
Nov 01, 2007 | Mitsubishi WS-55613 55" Rear Projection...
Trouble w/ my Phillips 50P8341 50 IN. HELP!!!
there is most likely a prob. with the keybd. switches all need to be replaced at the same time.
Aug 22, 2007 | Philips 50P8341 50" Rear Projection...
TV remote will not work properly
I have a Mitsubishi WD-52725 TV, too, and have experienced the same problems with it. My solution to the remote not responding is to push the reset button on the front of the TV (to the left of the Power button) with a paper clip and wait for the green light to stop blinking (about 1 minute). Then, turn it back on and try the remote again. Recently, my remote stopped responding when pushing certain buttons on it. I removed the batteries, and all of the little screws including the one inside the battery compartment and gently cleaned the contacts inside the remote and the circuit board with a cotton swab dipped in alcohol. After putting it back together, it works fine now.
Feb 28, 2007 | Mitsubishi WD-52725 52". Rear Projection...
TV not responding to remote
you can check your remote with a celular camera turn on the camera and point to the lens you most see the remote blinking if yes then wait for techman he will give you somes tips...good luck
Aug 05, 2006 | Samsung HCJ552W 55" Rear Projection...
Philips 64P8341 64" Rear Projection Television Logo
Top Philips Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Projection Television Expert? Answer questions, earn points and help others
