Question about NEC MultiSync FE2111SB 22" CRT Monitor
A part of the screen vanishes gradually up to down it started about 3 weeks ago with a small part in the upper part of the screen is vanished and replaced with a thin horizontal line as if this part is pressurized in this line as time running ,a bigger part of the screen vanished .now i am working in the lower half of the screen please help email:eng_ahmed_morsy_21218@yahoo.com
3 Suggested Answers
SOURCE: on screen thin yellow and blue vertical lines.
Unfortunately the LCD is going faulty.. one or more of the "Driver" transistors that operates the LCD elements RGB, have faulted ON.. perhaps this link may help fix it. Otherwise :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Posted on Aug 01, 2007
blueextc3221
  • 15935 Answers
SOURCE: thin red line in middle of screen on nec 42 inch plasma monitor
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago. While I disconnected the camera I left the other end of the connector cable plugged into the T.V.. As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected. It can lead to problems with electrical interference and appears to have been the problem in this case; When I disconnected this cable from the T.V. the red bars went away.
So, check your cables. Make sure everything is properly connected and get rid of anything that might be picking up interference.
Posted on Dec 27, 2008
China tv TH-2906 fbt number send me plz
I doubt you will find one most items from China live for a bit then vanish, if its a fbt with a glass tube screen to work then I would rate your chances at almost zero.
A number will exsist on the transformers body but this may be a variant made under licence for a manufacturer so only that manufacturer will be able to supply it even if you tracked down who made it for them.
Worse it may be a common failure part in which case it goes even quicker, an Hitachi of long ago used to have a higher failure rate than normal on one it was a "problem set" at 3 years old vanished at 5years.
Find out who made it imported it but I doubt it will help sorry......
Mar 04, 2015 | Televison & Video
I CAN NOT FIND THE CONVERGENCE MENU ON TV WHAT IS IT UNDER?
If set was made from around 2002-2006 it is in main menu---note some have a problem where it vanished from menu---means a protect part is bad---there is for those a small kit with 3 parts.
What happens in these (D52 etc) is bad connections at the high voltage transformer take one of those 3 parts out (cap, diode, protect part) and it vanishes from the menu.
Model number ?????
Jun 10, 2012 | RCA Televison & Video
Just got my Mongoose 26" Vanish about a week ago.
Fix it. Flats are a fact of life. Learn to deal with them. carry a pump, a tube and a patch kit.
Google "fix flat tire bike" for how-to's. Always try to determine the cause of the flat prior to removing the tube or you may just get another one.
Feb 27, 2011 | Cycling
Vanish of partition
drive (c) can manage small space and remaining space for saving data.
the partiton can be disappear when viruse interact in opaeratin system.
Jul 18, 2010 | Seagate (AU-80GBSATAHD) 160 GB SATA Hard...
Screen has turned white no display
my screen is not appearing it started last four moths after some few minutes the time comes and when any of the key pad is pushed sudden it will vanish and the screen turns white.
Jun 08, 2009 | Sony Ericsson K750
Ilo Audio Problems
try to resoldel the chroma ic section.
Nov 09, 2008 | iLO 3200 32 in. LCD Television
Dent
small dent can be retouched,retouched by a auto patty w/ hardener brand (best i use is bontite) squeeze with a pair of metal pallet use by auto painter,retouch using metal pallet gradually until dent was vanish.carefully apllied this not to scatter to a large size just on dent portion,use metal sand paper size # 600 follow up by # 1000 to have smooth surface,then spray paint gradually the same color as your unit,the color of your paint match to your refrigerator is available on auto paint supplier that mix and acquired
the color you want match to your unit.
Sep 18, 2008 | Whirlpool GS6SHEXNL Side by Side...
XP Pro Problm
can you explain the problem more? what do you mean vanished? does the screen fade out to white or black, or there is a blue screen with white text, or does it restart the whole system?
Mar 05, 2008 | Microsoft Windows XP Professional With...
"VIDEO 3" ON SCREEN
It is normal for VIDEO 3 to be displayed in the upper left of the picture if there is no signal present at the INPUT 3 jacks. This is to let you know that although the picture is black and there is no sound, the TV is still on. If you have a good signal at INPUT 3 and the VIDEO 3 stays on the screen, take the Sony remote, point it at the TV and press the DISPLAY button until you see "DISPLAY OFF" on the screen. About 3 seconds later, the words should vanish.
Aug 18, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
NEC MultiSync FE2111SB 22" CRT Monitor Logo
27 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
