Question about George A. Gathecha Google Search
Shannon gould - George A. Gathecha Google Search
Wire diagram 4 gould gt20
Wiring diagrams for pump motors are usually on the inside of the cover of the wire access cover or on the motor tag. If this is a 1/2 HP motor it could possibly be wired 125V or 250V. Be sure to wire for correct voltage.
Nov 06, 2014 | Goulds Pumps GOULDS GT20...
How do i prime a gould j5 pump
to make it easy to prime a pump I put a "T" piece in the suction line close to the pump. When it needs priming I take out the plug and put water in the line until the pump is full
Oct 17, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
WHERE DO I LOCATE THE FUEL SHUT OF SWITCH IN A 2006 HYUNDAI SONATA
Hi Shannon, Im glad to help!
Shannon, when a vehicle has a fuel shut off switch its always in the trunk and its a little box with a push button on it. If that doesn't fix it and you need further assistance call me Al 314-374-5218. I see you are in Wentzville area. I am in St Peters. Hope this helps and have an awesome day Shannon.
Sep 27, 2014 | Cars & Trucks
WHERE IS THE FUEL RESET SWITCH FOR A 2006HYUNDIA SONATA
Shannon, when the manufacture decides to put a Fuel Reset Button on there vehicles everyone that I have seen is in the TRUNK. You'll find a little box with a button on it. Hope this helps and have an awesome day Shannon.
Sep 27, 2014 | 2006 Hyundai Sonata
Why goulds septic pump buzzing
check for foreign objects jamming the impeller. have the motor tested for failure.
Jun 07, 2014 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Goulds pump
check for air leaks in the connections our your pressure switch is bad
Apr 24, 2013 | Goulds Pumps Goulds GT15 - IRRI-GATOR Self...
I have a 1/3hp goulds pump not working i have changed the capacitor and the centrifugal switch but it still does not work; does not come on what must i look at next.
Check the continuity of the service wires. If they are good, check the resistance of the windings. You may have an open motor windings.
Jun 08, 2009 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
George A. Gathecha Google Search Logo
Top George A. Gathecha Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a George A. Gathecha Facebook App Expert? Answer questions, earn points and help others
