Question about Wacom Cintiq 12WX Interactive Pen Display Monitor
The grip pen selects before I tap the screen. And to select something else, I have to take the pen away from the screen. And in the drawing area it always draws unless I am at least an inch away from the screen. I have restarted the "TabletWacomService", unplugged it all and back, calibrated, turned the screen off and on, cleaned the side panels and entire surface, changed the pen settings and restored them to defaults, and checked drivers.
4 Suggested Answers
SOURCE: Classic Pen Woes
Hi , Mnemosyne , i'm the Guest who had the exact same of your problem , i contacted WACOM and there solution was as follow : " This problem is, although uncommon, usually easily fixable. The first and fastest solution is to simply press the eraser a few times to release it from binding on the side of the pen. If that does not work, pull the white plastic nib, and take a fingernail file (LIGHTLY) to the back end of the nib, making sure to remove any burs or flaring from the nib. I have seen this problem myself, albeit uncommon " , they also suggested if all fails then change the nib ( and thats exactly what i did , i changed the plastic nib with the felt nib - i like it better anyways thats why i didn't bother filing the plastic nib - and WALA my problem was solved and the pen is working like a charm , hope this helps .
SLH
Posted on Jul 01, 2008
SOURCE: When I go into certian programs like inkscape or
I didn't solve it myself (a lady named Linda deserves the credit) ... but the solution at the following URL worked for me when I encountered the same problem with inkscape0.47 and intuos 4 wacom tablet pen:
http://inkscape-forum.andreas-s.net/topic/200534
Thanx, Linda!!!
cheers
zookumar
Posted on Feb 12, 2010
SOURCE: My wacom cintiq 12wx suddenly began to stop
Try installing the latest driver for the Cintiq 12wx at the Wacom.com website for the Vista operating system :)
Posted on Mar 03, 2010
Why won't my wacom grip pen click when it touches the tablet instead of hovering and selecting text?
Have you tried pulling the nib out (the end bit you draw with)? It could be that something is sticking the nib further inside the pen than it should, which is telling the pen you are applying pressure. As far as I know there is a little spring inside the pen that the nib pushes on when you touch the pen to the tablet. Perhaps the spring is permanently squished in.
May 26, 2014 | Wacom Intuos3 Grip Pen
How to cut a particular area in a given image quickly. For example in a image having a Horse in the grass field. I want only to cut the horse from rest of the image. How can I achieve this?
you can use pen tool to select by drawing around the image border perfectly and on joining the last dot and first .. right click and select make selection.. and drag it to another document
you can also use magic wand and tool to select th areas around the image and delete it
but using pen tool is the best way to get perfect cut..
hope it ll be helpful
comment and vote pls
May 18, 2010 | Adobe Photoshop 7.0 for PC
Pen for Intuos 3 hesitating with a pressure "ring" appearing after each tap of the pen. Lost hard drive, had to re-install and set up again. After setting up again, noticed this strange behavior. Tried...
I hope this doesn't sound stupid. Have you tried going into the settings for the tablet, and changing them around. It should give you a choice whether you want the mouse finder 'ring'. And give you a choice what you want for the pen pressing, buttons, and more.
May 17, 2010 | Wacom Intuos3 Graphic Tablet
Problem w/ Adesso Z12 Tablet
my adesso z12 was working fine and all of the sudden it started to ask me to reinstall driver. I uninstalled and re-installed the driver and it is still not recognizing the device
Dec 12, 2009 | Adesso Computers & Internet
How to set up my mms on my CECT p168+
MMS Messaging:
1.) From the main screen tap the SMS Text icon.
2.) Tap MMS on the Messages menu.
3.) Tap MMS settings on the MMS menu.
4.) Tap Server profile on the MMS settings menu.
5.) Tap either SIM1 or SIM2 on the MMS settings menu, whichever SIM you are setting up
at this time for MMS messaging.
6.) Scroll down the list until you come to Profile 8. You can use any profile if need be, but
profile 8 is usually the first not already filled.
7.) Tap on Profile 8. Tap Edit profile.
8.) Tap just below Rename profile, then tap on the Edit button at the bottom of the screen.
9.) Clear the current text, then tap in the following text between the quotes
“T-Mo MMS”
Tap the Options button at the bottom of the screen.
Tap the Done button.
10.) Tap the area below Homepage, then tap on the Edit button at the
11.) Clear the current text except for “HTTP://”, then tap in the
following text between the quotes after the HTTP://
“216.155.174.84/servlets/mms”
12.) Tap the area below Data account, then tap Select at the bottom of
the screen.
13.) Tap GPRS on the Data account menu.
14.) Scroll down the list until you come to T-Mo MMS, the data account
set up under the Data Account Services section. Tap on T-Mo MMS
to select it.
15.) Tap the area below Connection type, then tap Select at the bottom of
the screen.
16.) Tap on HTTP, then tap on OK at the bottom of the screen.
17.) Tap the area below Proxy address, use the numeric keyboard at the
bottom of the screen to tap in the following numbers,
“216155165050”. The result should look like 216.155.165.050 under
Proxy address.
18.) Tap the area below Proxy port, use the numeric
keyboard again to tap in the following numbers
“8080” to replace the current 0 value. Then tap OK.
19.) The areas under both User name & Password should
remain BLANK. If they are not blank, select each,
and Edit them by clearing all text.
20.) Next tap the Done button at the bottom of the screen.
21.) A Save? question box should pop up. Tap the Yes
22.) Tap the Activate profile button on the T-Mo MMS menu screen, and you should be
taken back to the Select profile screen where a big green check mark will be beside the
newly saved T-Mo MMS profile.
For full help topics I have a cd available fo 10 us dollars. Has 100's of mp3 ringtones wallpapers, and java games. Guarenteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope.
Apr 24, 2009 | Dual Electronics CECT P168 Cellular Phone
Can't multimedia message from sci phone how do i set up for at&t
must be peformed exactly.
MMS Messaging:
“T-Mo MMS”
the screen.
to select it.
the screen.
Proxy address.
Apr 18, 2009 | Dual Electronics CECT P168 Cellular Phone
Mac Cursor for Wacom Intuos2 tablet
How do I restore my Intus2 grip Pen on my Wacom tablet when it stops working due to various reasons; hitting the edge of the tablet area, drawing errors, etc.? I keep having to restart program and computer to restore it. Kinda a pain when it happens continuously. I am working in CS4 on Mac OS W vrsn 10.5.6. I am having this problem working in CS4 Illustrator probably would happen in Photoshop as well. Any solutions for resetting pen without having to restart each time??
mkohse
mkohse@ca.rr.com
Jan 24, 2008 | Computers & Internet
Pen dragging and skipping around the point where I press
Sometimes the grip pen get stucked because of dust or dirt, or the tip needs to be replaced. Clean the tip chamber or use a new one.
Oct 29, 2007 | Wacom (PTZ930AC) Graphic Tablet
Pen working incorrectly
I have the exact same problem, and I can't find anything, until now, on the web about it. I think perhaps the pen is defective because the mouse works fine.
Oct 20, 2007 | Wacom Graphire 4 "Silver" 4x5 (WMM132369)
Pen is always drawing
Dear All,
I have experienced the same problems in the aforementioned cases about the pen randomly highlighting things on the desktop/making selections, as well as loss of double tapping feature for double clicking. For my situation, I am pleased to say that I've managed to resolve the problem it may or may not help but worth a try. The solution:
(1) go to control panel and open up the 'Pen Tablet' icon,
(2) under 'Tracking' select 'Pen Mode' and click on 'Details' tab,
(3) under 'Screen Area' select 'Monitor' (*IMPORTANT*)
(* other settings I have are: 'unchecked' force proportions, 'Tablet Area' set to 'full', number of monitors under 'Screen Area' set to 1)
Following the above steps should remedy the problem. It worked for me. I hope it proves useful to you as well.
Kindest regards,
Jon
Sep 02, 2007 | Wacom Graphire 4 "Silver" 4x5 (WMM132369)
Wacom Cintiq 12WX Interactive Pen Display Monitor Logo
35 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
Ed Mac
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
