SOURCE: Acer Aspire 4520 display off suddenly without warning
Well, I'm only a few days into my new machine but as far as I can tell so far everything is great. It looks like the ultimate solution is to return it and get another one.
SOURCE: windows xp on acer aspire 4315 cannot shutdown normally
ARE YOU SAYING YOU SHUT DOWN WITH THE POWER BUTTON.GO TO START RUN AND SHUTDOWN OR RESTART THERE.RICHARDM69
SOURCE: sudden shutdown dell inspiron 6000
hi, i have something strange found in my inspiron 6000:
it looses SMD-parts in the dc-power-converter!
...strange isn't it?
maybe are the suddenly shutdowns the beginning of this ****!
you need someone who knows good soldering....
...and maybe someone can tell me which kind of parts the mine d6000 has loosen :oD ?
it came back from dell *without*...!!!
...please can someone post me a foto?...
thanx, lapdoc
SOURCE: Acer Aspire 5520 does not start up, power light blinking green
I think it might be the motherboard, if its not regulating the voltage properly then to much will go thru the motherboard and the fan won't be able to cool things down properly. Eventually then the motherboard will fail and then no video like your having now.
Try these steps anyway just to be sure:
only hook up the AC Adapter keep the battery disconnected. See if it turns on, if you still get a blinking green light then go ahead and turn the laptop off.
At this point, unseat and reseat the memory one stick at a time in each slot one at a time. Try turning on the laptop after each stick reinsertion.
If that doesn't do it then disconnect the hard drive and the dvd drive from the laptop.
Then try turning on the laptop, if you still can't get video then the motherboard is bad and would need to be replaced.
At this point at least you would know for sure.
SOURCE: Hi, I need help with
Hi
can you please check that the touchpad has not been locked i dont think it has but worth a try
by pressing FN+F7 or FN+F9
also check that the nulock has not been ingaged by mistake
also the scroll lock
or go to
start
all programs
acer
acer management
contents
scroll down to find the touchpad/pointing device
go over to the right by the green icon and hit the install tab
and let windows re install the touchpad
may be this will help
many thanks
oops, registry "leaks" not leads. The one about user profiles causing a registry issue.
