Question about Sony KDL-46W5150 TV
Sony Bravia model # KDL46W5150 is muting then shuts off,then a red light blinks 10 times. HELP?
welcomejee
  • 10594 Answers
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Posted on Mar 14, 2009
  • 116 Answers
SOURCE: 14 blinking red lights (standby) sony lcd
14 times means the LCD panel is defective. I just had one of those tvs in my shop. Sony will take care of the panel replacement in warranty.
Posted on Apr 15, 2009
  • 1039 Answers
SOURCE: 13 red standby flashing lights -- turns on, then turns off
Are you sure about the 13 flashes. Error code only goes to 8 flashes.
Posted on Apr 26, 2009
rustym62
  • 201 Answers
SOURCE: standby light blinks 13 times
13 blinks is backlight error.. can be 1 of 2 things, 1st bad inverter board (on left side panel looking from back) it has several plug ins to the panel as it supplies voltage to the backlights.2nd could be panel itself as backlights are built into it they can't be replaced. Inverter is probably around $200 +labor, panel= buy new tv... they are outrageously expensive. Good luck!
Posted on Apr 29, 2009
dsacco86
  • 1077 Answers
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
Bravia KDL52z5100. Why is red light blinking 14 times?
Tell the readers of your posting exactly what is the problem with the tv. Audiio? Picture? Backlighting? Etc.
Dec 29, 2015 | Sony Televison & Video
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
My sony bravia kdl46v5500 shows the 'digital fe/be error'. The stand-by red light blinks 10 times after the tv shuts itself off. The shut-off and then automatic turn on happened earlier after a while
  • i think you have a power supply issue but this model has been known for main boarde issues , if you replace the main make sure it is one that has the factory software loaded
Oct 04, 2014 | Televison & Video
My sony Bravia Model KDL 46ex523 shut down today , it has the little red light blinking 2 times , any idea what it means ?
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Make a visual check of all PCBs looking for burnt/overheated parts.This will help identify the problem circuit.
Read more: http://www.agoraquest.com/viewtopic.php?topic=31721&forum=70#ixzz31Blk7TRX
Apr 02, 2014 | Televison & Video
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My bravia will not stay on.
If Bravia tv wont stay On and shuts Off itself that means it got some internal problem, you will see red light flashing on tv front in specific blinking time that is an error code, let me know how many times that red light is blinking after three seconds long pause to diagnose problem.
Thanks.
Feb 08, 2011 | Sony Bravia KDL-46VL130 TV
I have a 2008 Sony Bravia KDL-46W4100 that when I turn it on the red light blinks 14 times. Please help me troubleshoot this problem so I can order the correct part to fix this...
Please help me troubleshoot this problem so I can order the correct part to fix this television
Nov 16, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
No picture or sound. Red light blinking four times on sony bravia tv. Suspect power supply problem?
Red light blinking 4 times on Sony bravia TV.This is the problem of INVERTER BOARD.The inverter board has to be replaced.Every Sony bravia tv has a particular model number and the Inverter board part number depends on model number of the tv. As you have not mentioned the model number so the exact part number of the inverter board is hard to tell.But you can get the required inverter board part for your tv from www.partstore.com ----------- Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation.
Aug 18, 2010 | Sony Televison & Video
Sony KDL-46W5150 TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
