Question about Sewing Machines
I've misplaced the manual for my White #1008 sewing machine. It's been a long time since I used it. Can't remember exactly how to thread it. I do remember though that there were some tension problems. But, I don't remember if it was at the top or the bottom at the bobbin.
  • Sandi Powell
    Sandi Powell Aug 02, 2013
    Those are not answers. They're money making schemes.
  • Sewing Machines Master
  • 7,365 Answers
You might try youtube for a video or go to the website of singer and contact their customer service and see if they can help you.
Posted on Aug 02, 2013
4 Suggested Answers
Mimito7
  • 128 Answers
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
Posted on Apr 19, 2009
  • 371 Answers
SOURCE: viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
  • 8 Answers
SOURCE: Bobbin thread breaks
Make sure your bobbin thread is turning clockwise as it sits in the bobbin case. There is a screw on the outside of the bobbin case you can turn with your thumb slightly to adjust tension. If you dangle the case from the thread and give it a light ****, it should move down slightly when doing so-an indicator of good bobbin tension.
Posted on May 20, 2008
Bernina 1008 thread tension is way too tight
Remember to raise the presser foot before you begin the upper threading process. May not be the problem, but you might try changing the needle and the type of thread you are using. Good luck with getting it fixed. Going back to the service provider is probably the best bet. You already paid for the service and they didn't fix the issue. Be sure to bring them a sample of how it is (mis)sewing.
I also pull the bobbin thread to the top of the fabric and gently hold both threads behind the presser foot until the machine completes the first stitch. That helps prevent the "thread nest" that is frequently created under your fabric. This is a procedure that is taught by Bernina instructors, and it does work.
Jun 23, 2015 | Bernina 1008
I cannot get the tension to set correctly on my Singer 6268 sewing machine. For instance, I'm using red thread on top spool and white in the bobbin. Suddenly, as it always does, the thread is loos
I have solved my tension problems by going to threadmagazine.com. they have solutions to many, many problems you have with your sewing machine. Hope this helps. jdokos95
Aug 01, 2012 | Sewing Machines
Misplaced my manual for my White #2037. Which
i was able to find manual at www.ifixmachines.com
Jan 06, 2010 | White Sewing 2037 Mechanical Sewing...
I have a Bernina 1008 and I love it, but every time I try to sew with it lately, the bottom thread wads up and makes a terrible mess. It will sew OK for a little bit and then the bobbin thread sort of...
Hi, I'm guessing you have the bobbin in the bobbincase upside down and its turning the wrong way. Or the machine is not thread correctly. Possibly there is junk in between the tension discs at the top that the thread goes between. Just some thoughts.
Rick
Sep 30, 2009 | Bernina 1008
Bernina 1008 sewing machine making huge clumps of loops on underside of fabric. have tried moving screw on bobbin in two opposite directions without a sign of improvement.
Hi: You have threaded the machine incorrectly. Rethread the machine with the presser foot up to the needle, pull the thread (loose) and drop the presser foot while pulling thread, thread should get tighter, then thread needle and machine will work fine. Make sure the top tension is set at where you normally have it, probably about #4 or #5
Jan 08, 2009 | Bernina 1008
The top thread keeps breaking on my White 1730, how can I fix?
go to the white website & email them from the contact us section. they'll email you back w/ PDF version of manual. they did that for me. goodluck!
Dec 16, 2008 | White Sewing 1730 Mechanical Sewing...
Threading a bernina serger
Here is a little jingle to remember as far as the order of threads to thread...
Upper looper, lower looper, left needle, right.
Usuall if you give numbers to the threads from left to right as 1,2,3,4 , you would thread it in the order of 3, 4, 2, 1 . Also when threading the loopers be sure the lower looper thread goes over the top of the upper looper thread as it goes out the back.
Hope this helps.
Sep 02, 2008 | Bernina 1008
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
